Depends if you want to upgrade the M1.1 to monos later on.Hi, what's better, a single M1.1 stereo or 2 mono 1.5?
Instead you should down grade your ears.The problem is if you start with CH,then always want to upgrade
I will upgrade M1 to M1.1,i would like to upgrade,L1 with X 1 to L 10,then to P 10,then to L 10 mono,ecc,ecc
You dont need to upgrade however if you want to you don't need to sell what you already have. That is what this nice about this line.The problem is if you start with CH,then always want to upgrade
not a downgrade my friendDear Tang,
problem my ears cannot accept,
and push me every day for L10 mono
but problem i have to downgrade for L10 stereo
It is amazing, starting with the listening room which is acustically treated from the conception on. Each detail was taken care of.That's a pretty amazing setup. By all reports CH's latest series of gear has nailed it which has wetted my apetite to hear more of them.
