I couldn`t agree more. Class D done right sounds very musical and without a sound that many associate with typical "class D sound". Such as listening-fatigue, dryness, etc. I experience none of this, my system sounds more like a tube-based system. IMO!My impetus to examine class D in more depth was simply driven by hearing some that really didn't sound bad at all. I came to realize that this rising star of the last 15 years was reaching ascendancy and if I didn't take it seriously I might get left behind. That was 6 1/2 years ago. It took us a while but we got the amp going. Now as some of you know my company makes all triode class A2 zero feedback fully differential balanced OTLs. They've gotten plenty of nice reviews over the decades as well as many awards.
I switched over from the tube amps at home to the class D about a year ago. Its nice to be able to say it is just as smooth in the mids and highs as the tubes were. Its a bit more transparent. I don't miss the tubes at all.
My point here is raw materials, cost, overhead and all that had nothing to do with it. The sound and the sound alone did. Its a happy coincidence that the amp draws so much less power, makes almost no heat, is smaller and that goes with that. IMO tube power amps are on borrowed time and class A of any type is too.
It takes far less 'embedded energy' to build a class D amp than it does to build a tube amplifier! Tubes take a lot of energy to build- more than most semiconductors. Plus you have to mine the materials and take the energy to build the output transformers and provide for a filament supply. Tubes of course have fairly short life cycles.But all assumptions aside does anyone here have any background in life cycle assessment or any specific data on embedded energy (gross process requirements especially) versus operational energy for any of the general types of amplifiers being discussed here let alone specific models of amplifiers.
Ralph, can you give actual measured data in terms of embedded energy of any class d amplifier and the embedded energy of any tube amplifier or are you just making assumptions in this?It takes far less 'embedded energy' to build a class D amp than it does to build a tube amplifier! Tubes take a lot of energy to build- more than most semiconductors. Plus you have to mine the materials and take the energy to build the output transformers and provide for a filament supply. Tubes of course have fairly short life cycles.
in a class A or AB amplifier the energy to build the amp is also higher than class D on account of the materials needed to make the larger heatsinks, larger chassis and so on. Since there is more heat the filter capacitors might have a shorter life. The output devices have a lifespan related to their heating cycles. I'm sure its better now than when I was in school; back then you needed hundreds of thousands of heat cycles to short the output devices so I think that's a wash these days.
The semiconductor industry seems like they want to make switching devices rather than linear devices. If that is so the energy used to make output transistors for class D applications should be lower.
The actual energy to run a class D for a given output power is considerably lower as you know. So any way you look at it class D amps take less energy regardless of how you classify the energy.
Can you outline what criteria are typically involved in a full sustainability life cycle assessment of a product or service?…. I’m sure if you could that you’d know exactly how much research would be required to create any real finding that one product is more “environmentally friendly” than another.Yes, thanks
I suggest you seek video of what is required to make a vacuum tube and produce the elements of which its composed.Ralph, can you give actual measured data in terms of embedded energy of any class d amplifier and the embedded energy of any tube amplifier or are you just making assumptions in this?
Toa, why don't you listen to some great music instead of wasting your precious time here in this thread?Can you outline what criteria are typically involved in a full sustainability life cycle assessment of a product or service?…. I’m sure if you could that you’d know exactly how much research would be required to create any real finding that one product is more “environmentally friendly” than another.
Even just an essential carbon accounting of a product or service requires extraordinary levels of measurement and research. I’m genuinely waiting to see any proper peer reviewed science happen in this discussion at all.
Wise words Christoph. Lol and yes, but I do find it strange that some talk about the value of measurements and I usually balance that with the importance of subjective evaluation… and then at last when I’m finally agreeing that in an area measurements are the only important thing it gets all unscientific and any truth is being lost behind the repeated clouds of guesswork.Toa, why don't you listen to some great music instead of wasting your precious time here in this thread?
Life is so much better if you don't jump over every stick someone holds in front of you
If the positions are completely diametral, there will never be a consensus and then it's better to agree to disagree.Wise words Christoph. Lol and yes, but I do find it strange that some talk about the value of measurements and I usually balance that with the importance of subjective evaluation… and then at last when I’m finally agreeing that in an area measurements are the only important thing it gets all strangely unscientific and any truth is being lost behind the clouds of guesswork.
Frankly if you apply a modicum of imagination and common sense, you'll realise it's obvious. Why is something so obvious so difficult for one or two here to understand? It's a bit like asking someone to prove that trees are bigger than shrubs!Ralph, can you give actual measured data in terms of embedded energy of any class d amplifier and the embedded energy of any tube amplifier or are you just making assumptions in this?
Well, if you can't separate informal coffee talk from audio debates it is your problem. This discussion is pure WBF speculation in our usual style, driven by intuition. Trying to connect it with audio measurements and subjective evaluation - I praise both a lot - is absurd.
This isn't quite correct! The objective is: by having both sides conduct (not go into cutoff) and by placing both halves in their most linear operating region, distortion is minimized. It is not to simply keep both halves 'active'.The objective of class A operation is to keep both halves (in case of a push pull design) of the amplifier active at all times.
Agreed, I swapped method and objective, but essentially meant to say the same.This isn't quite correct! The objective is: by having both sides conduct (not go into cutoff) and by placing both halves in their most linear operating region, distortion is minimized. It is not to simply keep both halves 'active'.
This technique is only required to reduce distortion if the design cannot employ sufficient feedback or if the design uses none at all.
Why do you need to limit feedback?Agreed, I swapped method and objective, but essentially meant to say the same.
The idea here is to limit the amount of overall feedback needed to get sufficiently low distortion.
The discussion on feedback is always an interesting one, the school of thought to have as much feedback as possible and the one to have limited or no feedback. Most of the reasoning and results are pretty subjective, which is what makes this such an interesting field.Why do you need to limit feedback?
Here's food for thought thenThe discussion on feedback is always an interesting one, the school of thought to have as much feedback as possible and the one to have limited or no feedback. Most of the reasoning and results are pretty subjective, which is what makes this such an interesting field.
Applying as much feedback as possible certainly has its merits in lowering output impedance and distortion measurements, but it doesn't play nice with our way to keep both halves conducting at all times.
