Merry X mas .
It seems Al and i understand each other
Oh definitely you two have things in common
Merry X mas .
This is what audio forums are for .I have to strongly disagree here. Those who love tranformer-coupled SET amps do so for their true-to-life timbre and harmonics as well as their uniquely musical properties.
However, it is interesting to note that OTL SET's lack this extra musical magic, producing the recording exactly as it sounds.
Agree about the lack of magic, but "exactly as it sounds" is not a description I find useful. Is it just an excuse for joyless sound? Does it also describe the sound of an over engineered, deep nfb, vanishing distortion SS amp?
Supercars from.the 1950 s .
Low power simple circuit .
Set lovers are stuck in the past / nostalgia
Thank you for your kind words! Seems to me a topic for another thread?I am interested in learning what the reason is. I am new to SETs, and have not thought much about how or why they made a comeback. I just do not follow the history of the industry. You have piqued my interest. Thank you.
One reason balanced connections don't seem to flatten single-ended connections in a fair fight is that there is a standard for balanced line connections that hardly anyone in high end audio observes. There are actually two- the most important being AES48 (Audio Engineering Society file 48). You would not consider using a digital cable that didn't conform to the standards for that type of connection but for some reason its OK if regular audio equipment doesn't??! The other standard is either -4dBm or +10dBm. This is the reading you would have on a VU meter while the source is driving a 600 Ohm load.The Modern Audio Police are going to have pry my unbalanced interconnects and my SET amplifiers out of my cold, dead outlets.
And me, FWIW... I started as an audiophile before I was even out of high school. IMO if you are getting into this sport for anything other than fun, its likely for the wrong reasons; wrong reason #1 is 'to make money'.BTW sound engineers generalization excludes Jean Hiraga
Simpler is often better. But as Einstein points out, its possible to be too simple. Another example besides SETs is passive volume controls which are insanely sensitive to what cable you use and can change the sound of the system (other than volume) as the volume setting is changed. A buffered volume control can work a lot better.Often, simpler is better. And some SETs allow you to experience the performance captured on the recording as though you are there and now.
Getting rid of the transformers gets rid of the elliptical load line problem I linked earlier.However, it is interesting to note that OTL SET's lack this extra musical magic, producing the recording exactly as it sounds.
If I can recommend the Swarm subs, they are designed to be placed directly against the wall without being boomy. They are a foot square and about 2 feet high so are fairly easy to place. I have limited space in my room as well so I understand the issue! Because my main speakers are good to 20Hz I only needed a pair of the Swarm subs (which are also good to 20Hz). I use them to break up a massive standing wave that no DSP room correction or room treatment would have a prayer of fixing. They are very effective! I have the drivers facing the wall so as to be certain they are inside the room boundary effect.Of course I would like to experiment with a pair of sensitive subs and crossover, but my current room is not big enough and I am very happy now anyway.
Which manufacturers are you talking about here? I have trouble believing that ARC's, Gryphon's, Boulder's, VAC's, VTL's balanced preamplifiers and balanced amplifiers are not true differential designs.. . . there is a standard for balanced line connections that hardly anyone in high end audio observes. There are actually two- the most important being AES48 (Audio Engineering Society file 48).
+1Those who love tranformer-coupled SET amps do so for their true-to-life timbre and harmonics as well as their uniquely musical properties.
Yes.Which manufacturers are you talking about here? I have trouble believing that ARC's, Gryphon's, Boulder's, VAC's, VTL's balanced preamplifiers and balanced amplifiers are not true differential designs.
Are you suggesting that these major (in high-end audio terms) manufacturers are not conforming to AES balanced connection and differential circuit standards?
Yes.
I didn't say they aren't true balanced designs. But that is different from supporting the standard. You can have a preamp that is entirely single-ended internally but interfaces to the world in the balanced domain.
AES48 pretty well calls for the output of a source to be floating. An output transformer can do that quite well since one side of its output can be tied to pin 2 of the XLR and the other side to pin 3, with no connection of the transformer to pin 1 (ground) at all. So it floats.
Put another way, the output of pin 2 should be generated with respect to pin 3 (its opposite) rather than ground and vice versa to support AES48. A sign that there is an issue here might be if there are RCA and XLR outputs present at the same time on a preamp without some sort of switch or the like to be operated depending on which output is used.
Since the common mode rejection of true balanced connections tends to cancel even order harmonics, isn't the preservation of such harmonics via single-ended connections a legitimate subjective sonic preference?One reason balanced connections don't seem to flatten single-ended connections in a fair fight . . .
The VAC uses output transformers so it supports AES48. That switch allows the output to float (balanced) or grounds pin 3 to pin1 so is then a single-ended output.Thank you, Ralph.
I don't know or understand the AES standards, so I cannot ask informed questions.
VAC preamps have a switch to select RCA or XLR outputs. Let's assume that the VAC preamp is a true differential circuit from input to output.
My uninformed question is: What's the problem with the VAC preamp regarding AES standards?
No.Since the common mode rejection of true balanced connections tends to cancel even order harmonics, isn't the preservation of such harmonics via single-ended connections a legitimate subjective sonic preference?
I apologize.The VAC uses output transformers so it supports AES48. That switch allows the output to float (balanced) or grounds pin 3 to pin1 so is then a single-ended output.
AES48 is nicely described in this article on Rane's website.
No.
I thought we had this conversation some months back. It does not work as you described; balanced line connections do not cancel harmonics of any kind full stop. Whatever harmonics can be transmitted in a single-ended connection the balanced connection will do exactly the same but probably preserving them better.
Now an internally balanced circuit can cancel even ordered distortion harmonics but it will not cancel even ordered harmonics of the signal itself. The distinction is what distortion the circuit itself makes as opposed to the harmonics present in the signal. They are not the same!!
This general theme has come in some of your posts, and to be sure, it is a head scratcher.So re-stating my question:
Since the common mode rejection of true balanced connections cancels even order harmonic distortion, isn't the preservation of such harmonic distortion via single-ended connections a legitimate subjective sonic preference?
I think that different people are after different things.It's all legitimate. People who listen a lot to live music under imperfect conditions are used to hearing distortions which to them sound natural or musical. Playing a pristine recording may or may not sound real/musical to them. I'm still trying to reproduce the joy I had 50 years ago listening to my SL 1200 and a 38 watt Technics receiver with my very best friends. My system now is 1000x more accurate but brings me no more joy. I love it but for different reasons.So re-stating my question:
Common mode noise is a noise signal induced in both conductors of a balanced line by an external source such as the EMF from a transformer. This gets cancelled eventually as the two phases are combined, as long as the noise is equal in amplitude and phase in both conductors. Any signal carried by the two conductors in a balanced connection is already in opposite phases (split either by a transformer or a phase splitter) and will not get cancelled when the two phases are combined, but added together.So re-stating my question:
That post is a mistake on my part- not adequately editing it for omitted words and the like. In this case what I was trying to say is that if the equipment is internally balanced (especially if differential) it will be inherently lower distortion as active balanced circuits can cancel even-ordered harmonics. This results in much lower distortion and since the 3rd harmonic is treated the same as the 2nd, it is able to mask higher ordered harmonics, which decrease at a faster rate as the order of the harmonic is increased as opposed to single-ended circuits. So in addition to inherently lower distortion also inherently more musical.So re-stating my question:
There is always the risk in posting on-line that someone will excavate the past to pit one's changed beliefs or mis-statements against your current self.
