I love sharks, marvels of evolution without which our oceans wouldn't function properly. But on another topic it always impresses me how much potential top components possess. My Ref 5SE was sounding a bit tired so I'm contemplating a change. Then I swap a KS1126 ic from the phono to the CDp, and voilà, big changes. More impact in the mid-range and bass to the extent that I have to dial down the subwoofers on the Tritons. It's about the synergy.
My amp came stock with those tubes and they are as you say...excellent. Since I was unable to source them, I went with Winged C 6550's which are also great.. And are now also very difficult to source.
I found them at RF Parts in San Marcos, CA for a lot less than Tube Depot or one or two other places that had them. I ended up buying 8 of them. 2 each for my preamp and phono pre and spares for each. I should be set for a while.
The NOS GE was a great tube - those I have measured had significantly lower leakage grid current than other brands or KT's compatible types. When the tube is used at low current, as in the ARC series regulators, this results in lower noise in the regulated voltage. However they are now very difficult to source. When I owned the VTL750's that used tens of 6550's I selected the best ones for the ARC power supplies.
It is ridiculous what they've have done for my Ref10 preamp. I never would have thought this was possible and was skeptical when I read Harlequin's comments but listening is believing. I'm looking forward to receiving two more for my Ref10 Phono.
Having rolled every 6550 this side of Pluto, For my part whilst the additional harmonic texture and liquidity inherant with the TS Black's gells particularly well with say Ella, Frank, Satchmo et al, I prefer the somewhat more "accurate " tho still harmonically rich ( compared to the stock Sovtek) GE with say, Fournier's JSBach 6 Suites for violoncello, Led Zep IV or The Ring Cycle, particular noticable on strung instruments and piano for instance
Personally, I consider the GE, and later production Sylvania for that matter, to be the best "all rounder " accross the various genres.
Sensible approach, Should you have not tried any other valves than ARC factory I would urge you to acquire a tested NOS General Electric 6550A in your Ref5SE, your current pre has much more to give without the stock Sovtek 6550 which is glassy and 2 D in comparison!
