Just to clarify Jkeny,
when I mention difficulty by that I mean one cannot approach it adhoc and usually requires a methodical-analytical mindset to identify,isolate and with training (whether formal or informal and ideally also understanding-awareness to some level of human behaviour with biases) for repeat passing subtle blind ABX in the context of looking for small differences such as outlined by Amir and a bit by me.
As you say and others such as Amir these type of ABX tests cannot be used to conclude beyond the fact audible differences can be accurately perceived; next part of investigation is why (it is not IM if we consider everything posted so far unless one pushes their equipment into stress and beyond spec close to clipping/distortion - which some of the tone examples will do and/or need to turn volume extremely loud breaking comparison test guidelines), and then what implications this has on listening generally/long term/tolerances-threshold/preference/etc as examples.
Edit:
Furthermore using the right source material (includes all aspects including recording-processing-etc) is critical as well and understanding the component chain and scope of said test.
Thanks
Orb
Edit:
Thanks
Orb
