I was JJ's (senior) boss.
Absolutely meaningless.
In this specific regard, it should have no weight at all. No one in the journal is vouching for ethics of the tests conducted by them.
Misdirection. The AES review board are not the same as the journal editorial staff.
http://www.aes.org/journal/authors/guidelines/
"Manuscripts are reviewed anonymously by members of the review board. After the reviewers' analysis and recommendation to the editors, the author is advised of either acceptance or rejection. On the basis of the reviewers' comments, the editor may request that the author make certain revisions which will allow the paper to be accepted for publication."
They have simply reviewed a paper and thought it rose above the minimum standard for publication.
False claim. The review board are not connected to the journal editorial staff and their identity is concealed from them and just about everybody else.
The test could have been completely fake and no one at the Journal would have caught it.
Misdirection. The Journal editorial staff are not supposed to catch such things. The Review Board are.
This kind of myth seems to not die. People keep thinking someone from the journal showed up and loo
ked over people's shoulders to make sure they were testing things correctly and audited the process when in reality no technical peer review is ever conducted that way.
It is possible that something like an on-site inspection might happen. Or the details of the experiment might inspect it by other means. The designated members of the Review Board do for sure interact directly with the authors. Presumably the interactions are designed to conceal the identity of the review board, but I can tell you for sure that their comments are not intentionally veiled. If you recognize someone's identity from their writing style, you might even be correct.
I have explained this so many times but the myth keeps getting repeated per above. I know you have seen my explanation Arny in various threads.
As demonstrated above I know for sure that your statements are not always unbiased or even just a little bit accurate. I have it on good authority that you are human and that carries with it the possibility even sometimes certainty of bias and errors.
Why do you keep propagating the myth?
Because there is no myth in what I say. I have intimate knowledge of some of these matters.
And remember, these are the credentials of the authors:
They seem like pretty nice people but completely miss the standards for which you thought JJ is qualified.
The myth above is that all qualifications that are valid are identical.
They lack any prior experience in this field whatsoever.
That would be an example of making claims for which most lack the evidence to make. Please explain how you know Meyer and Moran say better than I do.
[/quote]I should be clear that I trust everything they have written as not being fraudulent. Due to lack of controls however, I don't trust the results of their work.
I agree with some of your comments and disagree with others. I wouldn't have done the test the way they did, but I'm not the only judge of such things.
There is nothing trivial about it with respect to forum arguments.
Forum arguments are informal communications, and not in the same league as publications in refereed professional publications.
There has not been such a development or you wouldn't be here and on AVS arguing so hard to create doubt about it.
I'm hardly arguing at all. I've absented myself from this forum for weeks and months at a time.
The evidence is super strong in two areas:
1. Trained/expert listeners have far better abilities than masses of public or even "audiophiles." Lack of their use is against best practices of the industry/research community and hence seriously undermines any test which did without them.
Agreed.
2. Test created by Arny himself and positioned as an impossibility, going as low as saying 32 Khz sampling is transparent, was falsified. According to your own most, for some 14 (?) years no one had managed to pass such tests. But now multiple people have (to varying degree).
Agreed. However the evidence that has been obtained to date is miniscule and may have serious doubts associated with it.
#1 is 100% supported by industry/research practices. It is a new concept for many on forums but not in real world. People are now getting educated and hopefully won't go around saying results of one set of blind tests applies to everyone else.
I've been saying such things on forums for decades. I agree that many audiophiles have no clue about any of this and that even yourself Amir have provided the results of sighted evaluations as earnest proof of your magical audio beliefs in the past several years.
#2 speaks for itself. No longer can you say Arny that this and that test says our hearing is that dull. You created a test for that and we passed it. It doesn't get better than this as the commercial goes.
I would seriously hope that it gets far better than this because I have seen far better than this many, many times.
