First off, sorry I was so crotchety in my last post to you. You resisted the temptation to reply in kind, and I tip my virtual hat to you for that. I bet if we met in person, we'd get along great, and our difference of opinion over this stuff wouldn't amount to a hill of beans.
Yes, I read your posts, even #101. How is the modeling that you provided not an example? Really? You need an answer to that beyond the fact that it is a model, and is not an example?
Yes,
really!
Let me explain, and I hope you find the reason for our disconnect amusing, because I do:
My kind (speaker designers) use modelling programs all the time to analyze and compare the low-frequency performance of speaker systems. It is much faster and more reliable for making
comparisons than running actual measurements, into which inconsistencies and human error can and do intrude. So it simply never occurred to me that you might consider computer modelling to be invalid. In that case, I will not be able to offer any evidence that you accept. So... I guess you can stop reading now, if you want to!
You have lots of people on your side who have a strong technical background. Maybe you could ask one of them if computer modelling of loudspeaker low-frequency performance is valid for making comparisons? Obviously there's limited incentive for you to do so, because their response might give my analysis a toe-hold of credibility.
Pick a passive sub. Pick an OTL amp. Measure the extension and the frequency response. That is an example. A model is a model.
If you provide the passive sub and OTL amp, and pay for shipping both ways, I will gladly do the measurements for you. Otherwise, what you are asking me to do for the sake of an obscure argument on a high end audio forum just isn't reasonable.
In all of this designing of speakers and selling of OTL amps and matching of the two and discovering of synergies between them you don't have one real world example?
I don't have any real-world examples that meet the requirements you have laid out (measurements done on subwoofers driven by OTL amps). I work with loudspeaker design every day, always taking amplifier output impedance into account, so I don't need to keep proving this stuff to myself over and over.
You didn't take, or even find, one real world measurement to support your hypothesis?
None that meet your criteria. I've never driven a subwoofer with an OTL amp, much less measured one.
I did exhaustive measurements of OTL amps and full-range speaker systems over the course of about six months, back in 2006. That established to my satisfaction the validity of taking amplifier output impedance into account in crossover design and in box design and tuning. Those measurements were lost in a hard drive crash a couple of years ago, so I no longer have them. I no longer need them, so it's not worth the time and effort for me to replicate them, even if doing so might just might score me a point in an internet squabble.
When you found a particularly good synergistic match, when your ears told you that the conventional wisdom had been trumped, you didn't take it into your testing room and see exactly what you had?
It was the other way around. I already knew exactly what I had. I found it by following the science, then took it into my living room to listen to it.
I do understand this, but when were we talking about apples to apples?
I have been describing an apples-to-apples comparison to you since post 87.
Does your model optimize the match between OTL and speaker and then force the SS example into the OTL's ideal?
No. Each speaker system is optimized for best possible response with its respective amplifier. We keep the box size and efficiency the same ("apples to apples"), but each speaker system can use whatever woofer and box tuning works best with its respective amplifier. Then we compare the bass response primarily for low-end extension (-3 dB point), but also for smoothness.
Do you imagine that a speaker of the same size and efficiency is going to the optimal match to both a 30 watt OTL amp and a 1000 watt class D sub amp?
Yes... but let me explain:
If we have two speaker systems of the same size and efficiency, one optimized for best response on the 30 watt OTL amp and the other for best response on the 1000 watt Class D amp, and we drive them both at the same power level, assuming neither one is driven into non-linearity (either thermal or mechanical), my claim is that the one on the OTL amp will have deeper bass extension. (I can even model that for you, if you'd like!! Sorry, couldn't resist.)
The amplifier power doesn't come into play in my claim. It does not enter into Hoffman's Iron Law, which is what my claim is focused on. The Iron Law is only about box size, bass extension, and efficiency.
As long as you refuse to accept computer modelling, I can't even offer any
evidence that meets your approval, much less
proof. Stick to that, and by internet standards, you are guaranteed to win.
Which is fine with me, my skeptical friend. My audience is the people who are open to things that challenge conventional wisdom. And obviously I think it helps my cause if they have reasonable trust in the work of Neville Theile and Richard Small (so I'm selectively accepting of conventional wisdom!), and accept that the engineers at companies like LinearX and Harris Technologies were faithful to the work of Thiele and Small when they wrote their loudspeaker modelling software.
