Cryogenic treatment of power outlets - recommended or not?
Myles, I haven't got the Tripoint. I believe LL21 does. Will be running a Westwick 8kVA balanced power transformer w/untreated UK sockets, and in parallel the Entreq Silver Tellus grounding system.
Sorry my bad.
What I never understood is why don't cable manufacturers jump in the annealing procedure (heat treatment)
Copper wire is usually cold drawn as far as I know , annealing would be ideal for stabilizing the material (stress relieve ), in the( metal) industry where I work in, its used all the time
Annealing, in metallurgy and materials science, is a heat treatment that alters a material to increase its ductility and to make it more workable. It involves heating a material to above its critical temperature, maintaining a suitable temperature, and then cooling. Annealing can induce ductility, soften material, relieve internal stresses, refine the structure by making it homogeneous, and improve cold working properties.
In the cases of copper, steel, silver, and brass, this process is performed by heating the material (generally until glowing) for a while and then slowly letting it cool to room temperature in still air. Copper, silver[1] and brass can be cooled slowly in air, or quickly by quenching in water, unlike ferrous metals, such as steel, which must be cooled slowly to anneal. In this fashion, the metal is softened and prepared for further work—such as shaping, stamping, or forming.
If you would like some honest, up to date, accurate answers to this question...Just ask me!!! I have been Cryo Treating Cables for personal and resale use for the past 3 years. I have an understanding of what it does to the metals and what can happen if things go awry. Some metals show greater results than others. Some rubber and plastic parts don't make it through the process. 100% rubber turns to dust in the process, man made rubber has no effect at all. Cheap vinyl coatings can become rigid and crack, soft plastics have a similar result. But as far as the process making a difference in the end sound result...That is a definite!!! If you'd like more information you can find it on my website, or you can ask me directly.
Rick
www.iceageaudio.com
