Thanks for pointing that out. I've been having this weird problem off and on with the file getting dropped from my web provider without notice. I re-uploaded it, so it should work now.
The best way to find out about it is to read the
tutorial and the
help contents. See also the
tutorial PDF file and the
tutorial example files. Here's a quick summary of an example optimization. My main beta tester, Jag768, has a problematic room with no way to move the subs. His measurements of mains and subs at 4 different listening positions with no EQ on any of the subs is as follows (with no smoothing):
Note the four positions have lots of ripple, and there is lots of variation in response from position to position. These four plots are actually the result of 20 measurements. Each position has 5 measurements, the 4 subs and the main speakers. They are summed together using complex summation (properly taking phase into account) in the software.
After optimization, using individual filters, gains and delays for each sub, the following result is achieved:
Note that the responses are much flatter, and there is quite a bit less response variation from one position to the next.
Finally, EQ that's common to all 4 subs is applied to flatten out the main listening position. This gives the following result.
