I see you removed the Select model from the line up. What are select owners supposed to think?
The Reference DAC has also been removed.
Both Reference and Select lines are discontinued.
This is because the new Cascade DAC is closest in price point to a Reference DAC/Reference Director pairing with performance that eclipses the Select DAC/Select or Reference Director pairing.
A new DAC to eclipse all of MSB’s prior efforts is forthcoming for those with some patience and seemingly unfettered financial means. We can only speculate on what that might look like? Even more DAC modules? Separate left and right channel power supplies for the analog converter chassis? Even better clock? Time will tell.
Toggle signature
Exclusive New South Wales (Australia) representative for Acoustical Systems.
Analog source : Brinkmann Audio Lagrange turntable with Acoustical Systems Special Decoupled Platter upgrade, thread drive and two tonearms (Acoustical Systems Axiom carrying an Acoustical Systems Archon MC and Brinkmann Audio 12.1 carrying a Lyra Dorian Mono).
Phono equalisation/preamplification : Jeff Rowland Cadence (x2) with BPS-1 battery power supply; Lamm Industries LP2 Deluxe (modified with better parts).
Digital source/passive preamp : MSB Technology Reference DAC and Reference Digital Director with Network Renderer module. Roon Nucleus Plus streaming from Tidal and Qobuz.
Loudspeaker system/amplification : SGR Audio MT3F (external all-analog active line-level crossovers with external solid state amplifiers for each passband - tweeter, midrange and bass). Wired with Basis Audio PSTT speaker cables (3 separate runs).
Interconnect cables : van den Hul D102 mk3 hybrid (terminated with Furutech XLR plugs).
Power cables and conditioning : Isotek Systems EVO3 Premier, EVO3 Solus and EVO3 Polaris.
Equipment racks : SGR Audio Model III Symphony (with Model V Statement extended top shelf for turntable).
Listening room : Dedicated sound-isolated space measuring 6.5 metres long x 4.8 metres wide x 3.0 metres high. First reflection zone treated with custom RPG BAD panels. Slap echo treated with a combination of absorption and diffusion products from Vicoustic. Bass absorption courtesy of PSI Audio AVAAs in front corners. Listening in relative near field using Eames Lounge Chair.
