Digital vs. vinyl (a non-perfect comparison)
manisandher
243
217
950
www.the2ndtier.com
A couple of videos of Chris Jones's 'No Sanctuary Here' (shot directly with my Samsung and its built-in mic):
Digital on system one:
Vinyl on system two:
The digital system isn't perfect, the vinyl system isn't perfect... but both sound very satisfying in reality (to my ears at least).
Mani
Reactions: Zorro
Al M.
8,797
4,550
1,213
Greater Boston
To me, over headphones, the voice sounds far more natural on the digital. Does that say anything about analog vs. digital in general? Of course not. Just something about those two particular systems/set-ups/masterings, and perhaps the vinyl pressing.
Reactions: manisandher
manisandher
243
217
950
www.the2ndtier.com
I believe they are from the same master.
The biggest difference between these two has nothing to do the medium or the gear... it's the room - one a dedicated listening room, the other my humble home office.
Mani.
Reactions: MPS and Al M.
Blue58
899
685
1,155
London, UK
Mani.
If the digital (24/44.1) is from Tidal or Qobuz I believe it is a remaster. If you have the CD ripped then it should be the same master as the vinyl.
cheers
manisandher
243
217
950
www.the2ndtier.com
The digital was a Tidal 16/44.1 stream.
Listening to them, I'm confident they're from the same master. I can easily check by capturing the vinyl with an ADC and comparing the FFTs - will do this at some point.
Mani.
Joe Whip
1,740
563
405
Wayne, PA
Wouldn’t a better comparison be playing them in the same system in the same room? Right now listening to a wonderful subscription concert from St. Martins in the Field through my 2 channel rig. Will check the videos out that way when it is finished.
manisandher
243
217
950
www.the2ndtier.com
Oh definitely.
My digital system uses DSP, so I can't simply connect an analogue source to it. It'd be possible to connect a DAC to my office system, but I'm not sure I have the inclination to try this any time soon.
For this thread at least, we'll have to make do with "a non-perfect comparison" :).
Mani.
