DOEPKE Residual Current Circuit Breaker AUDIO GRADE
justubes
198
99
158
In my case, the Gigawatt breakers installed after the Doepke somewhat madeup for the Deopke sounding overly calm for my system and preference.
It is very tube like sounding when i added it. It is excellent sounding otherwise, so calm and rich, it sounded sleepy to me.
Please swap back the previous rccb to confirm the effect is indeed less lively for you.
Stigmater
9
I’m in the middle of day 10 and it’s like there is no enough grip/power , all is mellow and nice but lack of dynamics is killing me.
Quick update: yesterday night things started to settled and bass returned and I felt its moving in right direction, played new MUSE album and it was not bad at all with deep cloudy soft bass.
today is 11 burnin day and bass is gone I feel like roller coaster
Blackmorec
704
1,158
213
Hi Stigmater,
my past 3.5 years has been about developing a State of the Audio art digital streaming system, Due to the number and regularity of improvements made, the system has spent most of its time running in. What I've learned is that it generally takes longer than you expected, brings a bigger improvement than you expected, often in areas you didn’t expect. But its not all endless waiting! Your SQ will normalize and improve in the short time frame mentioned and you’ll probably find it a nice improvement and completely acceptable, so the final improvement that comes a long time later will be a nice surprise. I have a Doepke/Gigawatt combination and it offers what feels like unlimited dynamics and dynamic response across a huge range of amplitudes. It supports SoTA PR&T and super rhythmical, massively lively and agile music. It was a major improvement over ‘Audiophile-grade’ fuses and a consumer grade RCCB, but it took a long time to completely run in….probably because the current draw is quite low for most of the time.
zacho
13
3
83
Hi guys! Just got my first home and now finalising my dedicated lines. I've gotten the Doepke DFS2 + 2x Gigawatt G-16A. Am now considering getting another G-16A but not sure if it'll present compatibility issues with the DFS2 since it's only got 2 terminals? Has anyone connected 3 MCBs to the DFS2??
agisthos
94
20
315
Why don't Gigawatt or Doepke just make an audiophile RCBO?
An RCBO combines the RCD and magnetic breaker (MCB) into a single device. The less devices the better, the less wire links daisy chaining these things, the better.
This way you can have one breaker device feeding a dedicated line to your system. Simpler and better. I have a 32A Hager RCBO right here. Combined with Gigawatt LCY-Evo in-wall cabling, this may be good enough for my next upgrade.
eagle33331
19
5
3
59
I'm in the process of adding a third line using Gigawatt 16a MCB's and also have a DFS2. I regret to tell you my sparks says the DSF2 can only handle 2 MCB's. Price on the DSF4 is £1469 inc vat in UK! I'm going to have to come up with a different solution. Maybe take a spur off one of the existing 2 lines if within the regs.
Blackmorec
704
1,158
213
I bought my Doepke from Kemp Electronics in the Netherlands
Here you go. You buy it VAT free in the NL and pay the VAT to UK customs
If you use ‘Wise’ for the Euro payment you get current exchange rate plus a small fee instead of the marked up rate + fee your UK bank charges.
eagle33331
19
5
3
59
That's incredibly helpful, thank you.I may try a non-hifi unit first, to gauge result; if I'm not satisfied compared to the previous, smaller Doepke, I'll go this route.
zacho
13
3
83
It can actually handle 3 but only if connected in series. Anschluss Erklärung DFS 2 Audio.png
Reactions: eagle33331
eagle33331
19
5
3
59
It can actually handle 3 but only if connected in series. View attachment 100518
Oh - even more helpful, thank you. Mine would be exactly like that. Before I send to my sparks, does it matter that the 3 MCB's add up to 48A but the RCCD is 40A? (I'm not an electrician..)
zacho
13
3
83
This is what I did to my new home. Haven't actually moved in. And also this diagram is directly from Doepke themselves. Of course, do take note that the input terminals on the Gigawatt is on opposite ends to the Doepke.
eagle33331
19
5
3
59
Hey Zacho, this is my current board. So we'll get a bigger board and just add the third Gigawatt in series?
zacho
13
3
83
I'm actually as clueless as you, I just did what Doepke recommended I did. I also did ask another forumer who had 3 Gigawatt MCB's installed and he also did connect in series. It's in the other MCB thread.
eagle33331
19
5
3
59
Are you in UK? Just wondering if Doepke's plan meets UK regs..
