From ITU BS.1116-1 "METHODS FOR THE SUBJECTIVE ASSESSMENT OF SMALL IMPAIRMENTS IN AUDIO SYSTEMS INCLUDING MULTICHANNEL SOUND SYSTEMS"
6. Programme material
Only critical material is to be used in order to reveal differences among systems under test. Critical material is that which
stresses the systems under test. There is no universally “suitable” programme material that can be used to assess all
systems under all conditions. Accordingly, critical programme material must be sought explicitly for each system to be
tested in each experiment. The search for good material is usually time-consuming; however, unless truly critical
material is found for each system, experiments will fail to reveal differences among systems and will be inconclusive.
It must be empirically and statistically shown that any failure to find differences among systems is not due to
experimental insensitivity because of poor choices of audio material, or any other weak aspects of the experiment, before
a “null” finding can be accepted as valid. In the extreme case where several or all systems are found to be fully
transparent, then it may be necessary to program special trials with low or medium anchors for the explicit purpose of
examining subject expertise (see Appendix 1).
These anchors must be known, (e.g. from previous research), to be detectable to expert listeners but not to inexpert
listeners. These anchors are introduced as test items to check not only for listener expertise but also for the sensitivity of
all other aspects of the experimental situation.
If these anchors, either embedded unpredictably within the context of apparently transparent items or else in a separate
test, are correctly identified by all listeners in a standard test method (§ 3 of this Annex) by applying the statistical
considerations outlined in Appendix 1, this may be used as evidence that the listener’s expertise was acceptable and that
there were no sensitivity problems in other aspects of the experimental situation. In this case, then, findings of apparent
transparency by these listeners is evidence for “true transparency”, for items or systems where those listeners cannot
differentiate coded from uncoded versions.
