It must be 500-800.Mine is still playing - I didn't get a chance to listen last night - will be exactly 250H for me this afternoon. Ian - how many hours are on your unit?
Thanks Yuen. I am always wondering what something like a high end Innous or a Taiko Extreme would compare to the internal card. I guess that sums itJVS of Stereophile (March 2025, p. 75) says: "Streaming with Roon: First I streamed far more music via the Innuos Statement Next-Gen music streamer and PhoenixNET switch than I have time and room to discuss.. Then I bypassed the Innuos duo and plugged my network's Ethernet directly into the DA2i. After changing the DA2i's input setting from USB to Ethernet, I was ready to test the DA2i sound using Roon ... without an outboard server. Having previously found Roon's sound a distinct second best to Innuos's proprietary playback software, I expected to be disappointed. Imagine my delight when, streaming Mozart's 'Haffner' Serenade, K250, from Mozart's Serenata (24/192 WAV, Harmonia Mundi/Qobuz), with the Munchener Kammerorchester conducted by Enrico Onofi, the DA2i delivered music almost as colorful, airy, and involving as what I heard when I used the InnuOS 'Sense' playback software to play the files directly from the Statement Next-Gen's internal SSD. The sound was almost as good as when played through devices that, together, cost $25,000 more than the DA2i and require two additional power cables, an extra Ethernet cable, and a USB cable. That's quite an accomplishment."
How did this turn out?I have a Synergistic Research Master Fuse in my current DV2 and really like it.
Debating if I will swap it into the DV2i when it arrives.......
I was also thinking of popping an SR master fuse into my DA2V3. I hard wired a QSA red into my existing Rockna Wavelight which made an unbelievable improvement. I'm not sure I can improve the DA2is sound as it's pretty bloody amazing right now. But interested to hear if others have done soHow did this turn out?
What size fuse did you get?I have a Synergistic Research Master Fuse in my current DV2 and really like it.
Definitely different sound signatures and approaches to digital with each. I haven't spent time with the others, but I know this is a style of sound that I like and the audio quality is fully satisfying to me. It does seem that the DA2i is a faster, more neutral, energetic, and perhaps smoother style, while the others seem to aim for the weight and tone of analog. I would wager there are some benefits with throwing substantially greater expense at the design, but then again, these could also be inefficient designs compared to DA2i.Probably unlikely, but curious to know how the DA2i would compare to the MSB Cascade and even Wadax Reference?
Master fuse arrived via FedEx this morning. Amazing. Good thing for me PartsConexxion is 2H from where I live. Fuse is in DAC playing but I won't sit to listen until later tonight. Installation was a bit of a chore.... But got everything all sorted eventually.I have placed an order for a Master Fuse for my DAC - should be here next week. Will let you all know what I hear once I get it in.
Going back to this question, has anyone listened to both and compared pros / cons? Would also be curious to know how the volume controls compare, as one is purely analog, and the other digital.Would be very interested in the 2i vs MPD-8, as similar platform but different approaches to power supply, isolation, and digital filters. Curious if their strengths start to converge at a certain point.
I would gander that the MPD8 may outperform in an amp only system, its output impedance is <1 ohm. I would be interested to hear impressions comparing MPD8 to DA2i as a DAC only into a preamp. Mostly for entertainment purposes as I have zero inclination to change the EMM DA2 V3.Going back to this question, has anyone listened to both and compared pros / cons? Would also be curious to know how the volume controls compare, as one is purely analog, and the other digital.
The main difference in electronics between the DV2 and MA3i is the power supply, the Converse Digital network board, and ceramic analogue board in the DV2. The improvements in the MA3i make it the choice for best sound. A DV2i would be better for the ceramic analogue board and power supply but I have no experience with this.I have previously listened to the MA3 and, thanks to the excellent feedback from everyone here on the improvements from the “i” & “V3” updates, have an MA3i on order.
Since then, an unexpected opportunity has cropped up for a pre-owned DV2 at an attractive price (less than 40% premium to a new MA3i).
Just wondering if anyone has compared or would be willing to hazard a guess as to how the MA3i (with the trickled down improvements) would compare to the DV2 (assuming that I do not upgrade to “V3” or “i” status).
Thanks.
Did you ever get a chance to test the 845 and the MK465? Just wondering how it sounded with the DV2v2 as I just bought mine and will be using it with those two headphone amps.Actually, I'm not at the show. I let the dealer who sold me the 2i to use it for the show so he could send out the other v2s he had to 1 person to test and the other one in to upgrade. This will allow the other folks to get them earlier.
However, word from the show is the combo on 1266 is "big gud". However, in general, the 2a3 is not everyone's first choice of headphone amps. Sure, the 1266 it does well, but Susvara and Tungsten are less compelling. The 845 wasn't working so they couldn't use it and that would have been my preference to test it out. 845 gives more of a 300b experience and the DV2v2 with the ampsandsound RO XL in the Abyss room at CanJam in LA was one of the big highlights. At Axpona, I was able to hear a DV2v2 with both Viva 845 and Mass Kobo 465 with Susvara and it was perhaps the best headphone experience I've had to date which is why I'm going up. Still, one more comparison to do. 2i vs MPD-8 me and a couple of other folks are working to line that up now.
