Etymotic ETY-Plugs High Fidelity Earplugs
Al M.
10,435
6,222
2,493
Greater Boston
Recently I bought these:
https://www.amazon.com/gp/product/B0015WJQ7A/
Highly recommended. After trying them out at home in front of my system, I used them when watching the movie "Bohemian Rhapsody" in our local cinema yesterday. These earplugs don't muffle the sound, they just make everything softer (12 -20 dB), with only a slight taming of the highs relative to the other frequencies, which is very welcome since most PA/auditorium systems have tipped-up highs anyway.
In the auditorium the sound reached measured peaks of 100 dBa (approx. 105 dB), which I did not want to exposed to (I'll take that as an exception at the symphony, but not for reproduced music). I enjoyed the music at a still loud, but not alarming level that could have damaged my ears. The sound was clean and clear, as if I had had no plugs in my ears, just a bit softer.
These are not the ones I used, but they may have nicer, shorter stems:
https://www.amazon.com/Etymotic-High-Fidelity-Earplugs-Standard-Packaging/dp/B00RM6Q9XW/
