Every ending marks a new beginning... or which tonearm to choose :)
iaxel
390
185
173
Saying farewell to my TW Raven GT turntable, I highly enjoyed my time with it, but it's time for an UPGRADE :D
With the GT I'll also sell my, beloved, Raven 10.5 tonearm - to have it sold as a set.
I have an additional arm, which was not my primary, an Ikeda IT-407.
At this moment, I can afford only one tonearm on the new turntable (soon to be revealed :)).
Should I:
1) Keep the Ikeda IT-407 and make it my primary tonearm
2) Sell the Ikeda and buy:
2.1) Kuzma 4P (4P 14''?)
2.2) Graham Phantom III
2.3) Acoustical Systems Aquilar
2.4) Any other suggestions are welcome :)
Initially I will use this tonearm with my ZYX Ultimate Omega, which is my preferred cartridge.
Would love to hear your suggestions/opinions!
Thanks!
shakti
1,444
2,412
480
Cologne, Germany
I had Kuzma 4p 12' and Graham Phantom, both were outperformed by the Ikeda 407.
Depending on the Cartridge the Ikeda 407 was outperformed by Fidelity Research FR64s or 66s.
XV-1
3,620
2,637
1,860
Sydney
Thales Simplicity II or new Reference. Tangential tracking with a pivoted tonearm.
bonzo75
22,650
13,687
2,710
London
Good to know about the kuzma and the Graham. Which model of the Graham?
Also on which carts were the compares?
iaxel
390
185
173
Indeed very interesting, unfortunately, current pricing does not allow it to fit my budget.
iaxel
390
185
173
Thanks! I'm also intrigued (as bonzo) to know which cartridges where fitted on these tonearms when the comparison was done.
bonzo75
22,650
13,687
2,710
London
iaxel, have you compared your Zyx with other Zyx models? Any feedback?
RaceDoc
34
27
125
Germany
To really better this line up of possible tonarms you should go for the outstanding ViV Rigid Float.
We have compared the cheaper aluminum version with the tonarms you mentioned and the ViV
was by a significant amount the best.
Very charming is that is it completely unimportant if the cartridge used is light or heavy, if the
compliance is high or low. This is because of the unique "mangetic oil bearing" of the ViV.
iaxel
390
185
173
Hi bonzo, sorry missed you question.
Actually, I've had the chance to compare 2 versions of the ZYX Ultimate Omega:
1) Gold wiring and high output (0.48)
2) Silver wiring and low output (0.24)
To my ears, the silver/low output version was much more resolving and dynamic, better overall. The gold/high output version was lusher and with less bite and attack. All in all, both are very refined cartridges, without sounding bright or etched - IMHO, this is the essence of high-end audio.
iaxel
390
185
173
Thanks!
I've read some mixed reviews about the Viv, but it is indeed an interesting tonearm.
Which length gave the best overall performance in your opinion?
bonzo75
22,650
13,687
2,710
London
Thanks, did you use a valve phono for the compares? If so, which one?
iaxel
390
185
173
