My top horn is 80cm diameter so they are big
They are around 180cm tall total.
That is taller than average person, I guess... True monsters. It looks like you will be able to wake up half of a city at once
My room could house themMy top horn is 80cm diameter so they are big
Christoph you should see if Bill can build you a tower MTM version with a slot loaded bass cabinet mirrored above and below the monster horn… that’d definitely start an avalanche up in your alpsMy room could house them
The "view-blocking-area" should not be bigger than the Universums but iIrc, the mid-horn of the Universums is also 80 cm diameterYour room could house a gigantic monster horn
Forget about "bringing the musicians to you"...more like bringing the landslide.Christoph you should see if Bill can build you a tower MTM version with a slot loaded bass cabinet mirrored above and below the monster horn… that’d definitely start an avalanche up in your alps
The one he has isn’t so small...Your room could house a gigantic monster horn
I have The following Field Coils Systems.
1 Pair of Classic Audio Loudspeakers T1.5 Full Field Coils (In the UK)
1 Pair of Classic Audio Loudspeakers T3.4 Full Field Coils (In indonesia)
1 Pair of LM-03 Full Field Coils In Indonesia.
For Music either Im using Active Studio Speakers from Quested Speakers from the UK Designed by Roger Quested, or Im Using Field Coils Horns.
All the Above Field Coils are used with Atma-Sphere Amplifiers.
Here is Line Magnetic Field Coil Super Tweeter, I will take more pictures in the coming week for the LM-03 Field Coils.
View attachment 80405 View attachment 80406 View attachment 80407 View attachment 80408
Any particular positions in particular order already on your list?Next I will sort out which amplifiers to use in order get the most out of them.
Would love to see those too!In order of interest:
1. Bespoke custom Single Ended OTL monos
2. Custom 45’s S.E.T. D.H.T. monos
3. Conventional OTL monos
Working on getting # 1 built, waiting on delivery of # 2 and contemplating # 3.
I want to match fast drivers with fast amplifiers.
and what frequency range are you shooting for?
What output tube will you use for the SET OTL? I have seen the 6c19pi be a usual choice for this rare amp type.In order of interest:
