Five favorite tweaks
1. Stillpoints Ultra SS. The improvement these made under every component was wild. Amp, power distributor, even grounding box. I became a believer and now realise isolation is critical.
2. Nordost QKore to QB8. Perhaps a special synergy is here between these two Nordost products, you have to hear it. But I have had far less success using QKore to ground other components, it’s been hit or miss, mostly miss.
3. Zilplex acoustic resonators. Like the Frank Tchang resonators but smaller and working on very high frequencies. Norm Luttbeg (rip) was a big proponent of this product. Expands the soundstage in your living room, does not effect tonality.
4. Rick Schultz’s magnetic High Fidelity cables. Not sure whether this falls under tweak category, but no other cables could come close for the same price, or at any price i am told. A thread about these cables with 20k comments was deleted off Audiogon. Rick is now making a new line of magnetic cables under his own brand name.
5. Track Audio Precision speaker stands. Srajan from 6moons still says these are the best stands ever made for bookshelf speakers. Makes a huge difference if you are into monitors. You don’t know what your bookshelves are capable of until they are on stands of this quality.
Unfortunately none of these tweaks comes cheap.
Now let me tell you about tweaks I used to use heavily but do not recommend anymore - any power filter, whether series or parallel. Years past when my system was less transparent all these power filters worked great. But as my system become much more resolving, filters now reduce micro dynamics and fine detail. All of them do, consistently. But at the same time you can get things like increased soundstage and perceived macro detail while this reduction occurs.
The user here called @Amir has talked about this and explained in words exactly what I experience.
And yet - I still keep buying these power filters as it’s a tweak I am addicted to!
Interesting thread. Here’s my top 5:
1. Upgraded AC outlet to feed audio system. Builder-grade AC outlets should not be feeding high end audio systems so substitutions can bring a huge bang for the buck improvement.
2. Audiophile fuses. Stock fuses tend to do harm so substitutions can bring a huge bang for the buck improvement.
3. Dedicated AC circuit. Again a huge bang for the buck in most cases.
4. Stacks of ASC tube traps in front two corners of a listening room. Possibly the biggest bang for the buck improvement I’ve experienced. “Head end ringing” does a tremendous amount of harm so the benefit from soaking this up can be tremendous.
5. Stillpoints or equivalent under everything, starting with the speakers.
Agree with everything.
Reactions: kennyb123
We of the so-called “Tweak” family-objects, object to this thread: we have been discriminated for decades, called “snake”oil and other foul terms by thick-minded scum, but no more:mad:. You “audiophiles” would be NOTHING without us. We are essential, we are COMPONENTS and nothing less. But since we are well-mannered, we still wish you all the best for 2025! Stay healthy and unbiased. Cheers.
Reactions: Republicoftexas69
