Vincent - Sorry for going slightly off-topic here, but do you know of any PC Video cards that have HDMI IN and OUT.
Something like this? http://www.blackmagic-design.com/products/intensity/
...in a earlier version they added some bass and lower midrange to the playback. In other words some EQ. And people were raving of how much better bass response they got with Amarra. Especially fun considering the fact that most of these audiophiles find EQ to be a curse.
My bridge is isolated. I verified that before I bought it .Before you do, check if there is a galvanic isolation between the PC and the DAC.
A async protocol sec might be insufficient if stray signals still can enter the DAC.
You made me think of testing how well they are isolated some day. Shouldn't be hard to measure its performance while trying different PCs.....
Though I've seen it denigrated in some places, I'm a fan of the 'live flop' method of subjective testing.
For example, I recently synced the playback of a pair of Squeezeboxes into a pair of DACs, then each of these was fed into my preamp. Flopping between the two was hitting a button on the remote -- the song continues without missing a beat. Very easy to hear tonal differences, etc. Idea is to take sonic memory, and it's relative the placebo effect, out of the equation as much as possible.
The Amarra demo has a button to bring it in and out of the playback chain. In some quick, casual listening, I heard no difference flopping it in and out on my Macbook Pro. Would more comprehensive testing reveal differences? Maybe, but when I hear talk of major improvement which I define as something easily discerned -- obvious -- I'm out.
Amir -- so if I understand you correctly, everyone's computer, because of hardware architecture, installed software, etc. could theoretically sound different. The variables are endless which makes the whole question of what sounds better case by case. Yes?
You can't argue with people like that. I just tell them "well, then, if lossless compression sounds worse, your hardware is broken", which, of course, it would have to be.
IF it sounded different.
(insert sound of birds chirping)
Ditto there being a real audible difference betweem FLAC (or other lossless compressed) and WAV playback. Might happen, theoretically, but it's probably placebo.
http://www.hydrogenaudio.org/forums/index.php?showtopic=79056&view=findpost&p=691525
You can choose 0 – 8 where 0 is no and 8 the highest compression.
I started about 5 years ago in this Computer music business. I can tell you that the single file + cue sheet is often maddening. I am still in a mixed environment. I was experimenting with ripping and used ape and flac since they allowed me lossless compression.
I find myself drifting toward flac but for no clear reason. Ape should be as good and both are free. Any reason Vincent why you prefer flac over ape or have I misread you ?
I think 0 is still compression. Try yourself. The compression level 0 allows the fastes deconding time.
Best
Pico
