$600/each- $4,800 for a pair of speakers
On the other hand, Stack Audio Auva 100 are getting very positive reviews and are $1,200 for the set of 8
HelloHello there,
Can someone recommend any footers or spike bases for heavy speakers around 350 kg ? Most products i see in the market seem to have a limitation below 300kg.
Thanks
I agreeI will be careful about footing your dual FLH type speakers, you might lose the midbass. You might initially think it is clean or something. Just be careful
AgreeI will be careful about footing your dual FLH type speakers, you might lose the midbass. You might initially think it is clean or something. Just be careful
$300/each$600/each- $4,800 for a pair of speakers
Forget about it
awesome$300/each
Carbide Bases under Altec A7/5 customs:
https://www.instagram.com/p/CqdIeHyKEeZ
https://www.instagram.com/p/CqdDE4yKdfb
$300/each
Spot on comment. In that case (losing midbass or enjoyment) I recommend adding Harmonix RF-999 spike bases.I will be careful about footing your dual FLH type speakers, you might lose the midbass. You might initially think it is clean or something. Just be careful
If you remove things and get better sound it's because you remove damping accessories (SRA platforms are as many others) or accessories that give a bright sound, a colored sound. There are so many accessories that change the sound but do not improve it and mostly degrade it. I also see that you use cable lifters with wood (a lot of damping too). Less is more is not a rule..In any case the bass is much less of an issue now since I’ve made a few changes under DDK’s guidance who was over at my place recently. Different listening position, removing SRA VR from under the linestage, etc.
It seems the more I remove from the system the better it sounds.
Agree,If you remove things and get better sound it's because you remove damping accessories (SRA platforms are as many others) or accessories that give a bright sound, a colored sound. There are so many accessories that change the sound but do not improve it and mostly degrade it. I also see that you use cable lifters with wood (a lot of damping too). Less is more is not a rule..
You use tubes electronics, all these kind of amplification is very sensitive about micro vibrations, even if some manufacturers use decoupling system inside. Testing a set of 4 HARMONIX cones (TU210 ZXM best, REI-168 or RS-777) + RF999Z bases could be interesting.Agree,
I'm not saying that "less is always better", just gave a specific example.
Going to remove SRAs from under the power amps, really curious what that would do.
How would Alsyvox footers compare to putting the panels on Townshend podiums as an example?Hello
The best feet are to my experience HARMONIX TU210 ZXM + RF999a+ base if your room has a thin carpet or wooden floor. If you have concrete hard floor, best is TU-210 ZXM + RF-999Z base.
I tested many feet in ball bearings system for Stillpoint to Cerabase, Jim (discontinued) and none are on par with the Japanese cones. The 2 other solutions are PRANAWIRE DanTien, certainly the best but quite expensive at 9000 USD/set of 4, and the new ALSYVOX O2 feet that will put the famed planars to another level. Introduction in May at MUNICH High end show. ALSYVOX design is proprietary and custom tuned for planars.
KR
PHP
Center Stage should also be considered IMHOYou use tubes electronics, all these kind of amplification is very sensitive about micro vibrations, even if some manufacturers use decoupling system inside. Testing a set of 4 HARMONIX cones (TU210 ZXM best, REI-168 or RS-777) + RF999Z bases could be interesting.
ALSYVOX had previously balls bearing system with synthetic ball. This was a very clever system to prevent vibration to affect aluminium ribbons. However ALSYVOX tried same concept but differently designed and the new O2 feet are really a huge improvement is clarity, definition, inner resolution. Trebles are more natural and bass is purer with more nuances.How would Alsyvox footers compare to putting the panels on Townshend podiums as an example?
I got massive increase in clarity and sound stage putting external crossover on vibration mgmt
