$600/each- $4,800 for a pair of speakers
On the other hand, Stack Audio Auva 100 are getting very positive reviews and are $1,200 for the set of 8
HelloHello there,
Can someone recommend any footers or spike bases for heavy speakers around 350 kg ? Most products i see in the market seem to have a limitation below 300kg.
Thanks
I agreeI will be careful about footing your dual FLH type speakers, you might lose the midbass. You might initially think it is clean or something. Just be careful
AgreeI will be careful about footing your dual FLH type speakers, you might lose the midbass. You might initially think it is clean or something. Just be careful
$300/each$600/each- $4,800 for a pair of speakers
Forget about it
awesome$300/each
Carbide Bases under Altec A7/5 customs:
https://www.instagram.com/p/CqdIeHyKEeZ
https://www.instagram.com/p/CqdDE4yKdfb
$300/each
Spot on comment. In that case (losing midbass or enjoyment) I recommend adding Harmonix RF-999 spike bases.I will be careful about footing your dual FLH type speakers, you might lose the midbass. You might initially think it is clean or something. Just be careful
If you remove things and get better sound it's because you remove damping accessories (SRA platforms are as many others) or accessories that give a bright sound, a colored sound. There are so many accessories that change the sound but do not improve it and mostly degrade it. I also see that you use cable lifters with wood (a lot of damping too). Less is more is not a rule..In any case the bass is much less of an issue now since I’ve made a few changes under DDK’s guidance who was over at my place recently. Different listening position, removing SRA VR from under the linestage, etc.
It seems the more I remove from the system the better it sounds.
Agree,If you remove things and get better sound it's because you remove damping accessories (SRA platforms are as many others) or accessories that give a bright sound, a colored sound. There are so many accessories that change the sound but do not improve it and mostly degrade it. I also see that you use cable lifters with wood (a lot of damping too). Less is more is not a rule..
You use tubes electronics, all these kind of amplification is very sensitive about micro vibrations, even if some manufacturers use decoupling system inside. Testing a set of 4 HARMONIX cones (TU210 ZXM best, REI-168 or RS-777) + RF999Z bases could be interesting.Agree,
I'm not saying that "less is always better", just gave a specific example.
Going to remove SRAs from under the power amps, really curious what that would do.
