In my experience, tube amps provide the magic.
Thats always been my findings too. i use all tubes right now, but have preferred SS preamp and tube amps when mixing the two.
I use a Musical Fidelity tube buffer because of the input impedence mismatching between my Lamm amps and the amps in the JL Audio Gotham subs
What (as far a impedance match) do you guys think about my Burmester 911 MK3 and Concert Fidelity CF-080 LX?
CF -080 LX:
Input Impedance: 100kohms
Outputs: 1-Line Level Output (RCA)
Gain: Selectable between 6dB and 12dB
Tube Complement: 12AU7 (2) for gain (tube-swapping possible), 6CA4 (1) for rectification
Burmester 911 MK3:
23K unbalanced
2K balanced
^ Thanks Miles, much appreciated.
Although in looking at it again, I don't know what the story is if using balanced. Also, I assume when you said input impedance on the CF, you meant output impedance?
The ratio is 10:1 that you want at minimum.
As a former pass amp owner, i can safely say there arent many tube preamps with low output impedance.
