The point was no one argues numbers.yet here arguing numbers. What is .5 children? Identify the couple with 2.5 children. That's the issue.That is not a problem. Your friend is above the average and you are below the average.
Amir,What I know is "if the science give us answer to a question then no body speak/discuss about it", for example no body speak about physics E= MC2 formula , nobody speak about 2 x 2 = 4 or 5.
Nobody speak about NA + CL = NACL or ...
If we had a scientific answer to this topic then we never discussed about it.
about my blind tests I should say me and my friends had many many blind tests in past. I remember sometimes our ears could not detect any difference between X vs Y , for example I have used some cable lifters but I did not detect any difference and I repeat the test but It proved me I can not detect effect of cable lifter under cables.
There are many tweaks that I can not detect any difference in blind tests but cables have very audible effect on sound.
My blind test:
1- I listen to A for hours and my brain focus on the sound to learn/memorize
2- I listen to B for hours and my brain focus on the sound to learn/memorize
I use different records.
3- I close my eyes and ask my friends to start the test. They repeat the test for 10 times and I should correctly detect which test is A or B. If my 10 answers are correct then it means I can hear the difference. If only one of answers be wrong then It means I can not detect A vs B.
Actually the difference are far more evidence if we have properly setup high performance systems. In many audio setups the difference of A vs B is very small.
WBF is surely international
Were discussing measurable freq responses , lets keep the discussion " scientific " and keep cables ( pseudo science ) out of the discussion.
Good cable sound in general starts at around 50 K / meter![]()
This hobby is called HIFI not MY FY or YOUR FY.I suppose you can interpret the results any way you like. If you correctly match A or B to X that would represent a 90% confidence level in your ability to hear a difference
Remember it is not a Pass Fail test.
You probably had expensive colouring cables before , then DDK gave you good quality industrial cables .Cables certainly make a difference. Mine were very carefully selected for my system based on sound. The interesting thing is that they are industrial wires and not high-end audio file cables. A few of them are no longer made and they are all inexpensive. In fact my dealer just gave them to me when I bought the rest of the equipment.
IOW you went from pseudo back to real science
If a artist / recording engineer tries to keep the signal within plus minus 2 db , the rest of the HIFI system should at least respect that
Frequency response discussed at kindegarden level is just pseudo science.![]()
There is nothing holy about what artists and recording engineers commit to the recording. These are the same people who instigated the loudness wars and dynamic range compression. Why should I respect that? If I am not happy with the way a recording sounds, there are ways to do something about it.
Ron, I will bow to the many experts here but I think the answer to your question is the varying sensitivity our ears have across 20Hz to 20K hz frequency range.. Better know as the Fletcher-Munson curves or equal loudness contours. Basically, our ears are much less sensitive to bass and sub bass than they are to midrange.I agree with this. To my ears flat sounds way bright. (On this I agree very strongly with Karen Sumner's point that the music lives in the 100 Hz to 1000 Hz range, and it is a puzzle why manufacturers celebrate extended high frequency response.)
What I don't understand is why this downward-sloping curve subjectively sounds pretty neutral to me and to many visitors, and not rolled off:
Which is why a FLAT ‘weighting’ should not be used when using your frequency response app but A weighting which adjusts for our hearing response as pointed out here.Ron, I will bow to the many experts here but I think the answer to your question is the varying sensitivity our ears have across 20Hz to 20K hz frequency range.. Better know as the Fletcher-Munson curves or equal loudness contours. Basically, our ears are much less sensitive to bass and sub bass than they are to midrange.
Equal-loudness contour - Wikipedia
en.wikipedia.org
Good cable sound in general starts at around 12 AWGGood cable sound in general starts at around 50 K / meter![]()
Glad to see that you are slowly coming around, your audio knowledge has just been upgraded with the Nth degreeJust very recently, for the very first time, I started using frequency response charts for my system/listening room. I think it is an interesting tool, for a specific purpose.
I am finding it very interesting to see if I can see on the objective frequency response chart what I subjectively think I am hearing with my ears.
You are actually right, there is also phase, THD, IMD, S/N ratio, off-axis FR and then some.Honestly, this post isn't about much other than my need to vent out about those who insist there's no more to audio performance than frequency response.
I see comments like this in here a lot, just in different writing. Nobody who works seriously with audio, says that the listener is not important. There has been written heavily important books, about how we interpret sound. I would allow myself to say that we have come pretty far on this subject. So when a lot of people on this forum, claims that the objectivist are only looking at graphs, the at least give us an example of such a person. Otherwise it is just strawman argumentation, that only serves to confuse and ridicule those who (also) have a serious approach.first of all, we don't listen to numbers or graphs. we enjoy the art of music,
