Understood and thanks. I've actually found through experience that more so than with bass, if the mid is "weak" or less prominent, then the highs sound more prominent (opposite is also true). The bass commonly has more of an effect on the mids or more specifically mid - bass depending on its output.
Also, I dont have many tweaks in the chain and my system components are, if anything more forgiving and on the warmer side (Wells amp, Purity tube preamp, Aqua DAC).
In addition, I have measured the Vivids on and off axis, toe in, and straight ahead (no toe - in). There is absolutely no high frequency roll - off with the Vivids and as such, toe - in exacerbates the highs. The result is - not much toe - in is preferable which is likely why the vast majority of demos I've seen have them with very little to no toe - in. It's also what's recommended by dealers. The G1 likely doesn't have this issue with the tweeter much higher than the average listening chair. As I understand it, this is a design choice.
All that said, there are ways to mitigate it individually or a combination of - 1) raising the speaker 2) no toe - in (described earlier) 3) carefully applied DSP 4) rake angle (rake back aiming the speaker upwards). Each has its pros and cons and as everything in audio it's all a series of compromises. Thanks again for the input.
