I wonder why Lukasz does that (high output voltage on dacs). Even with 300B I normally listen at the 9 o'clock position on my pre. I've found this quote at Rothwell site:Agreed but I think people have simply been using them in series on hot output. Lampi dacs typically run quite hot on the output voltage, up to 6v rather than the 2v standard
"Here's the solution to a problem from which far too many audiophiles suffer - too much gain in the system. The symptoms are easy enough to spot - the volume is plenty loud enough with the volume control set to the 9 o'clock position, too loud with the volume control at 10 o'clock, and fine control at low levels is impossible. This may seem like nothing more than a minor irritation, but in truth the performance of the system is being compromised. Although potentiometers work reasonably well over most of their operating range, they are notoriously problematic at extreme settings. The most obvious problem is channel imbalance - one channel will fade out (or fade in) quicker than the other, causing the stereo image to shift to one side - but on a more subtle level, the music may sound veiled and indistinct with the volume control turned down to the point where it is nearly off".
Is this true? Is the sound quality affected in any way, if I usually listen at the 9 o'clock position?
Thanks.
