Then 242 will be the best for you, most probably, because Lire7 does not suffer from the gain issues of GG. In fact it was Lukasz's favorite for big 7, and audiophile Bill's friend who had a Lite bought them and loved them, more upgraded to GG
There is a problem with my Pass / Lampi setup and 242 is not possible.
What's the problem?
Al feels the 101d is a very nice tube
Hi Sujay! Glad to hear you are liking your GG with the updates.
Do you know how the low/high gain switch works? Is it just a set of resistors on the output or does it do something else to the tube gain?
I'm wondering if I can recreate it in my system. I'm still suffering from insufficient gain even with 242s, resulting in too high noise floor with the DSD512 engine especially with quieter tracks.
Do you have any issues with noise/hum with the dsd512 engine with quiet tracks?
As far as I am aware, they are just a set of resistors but I am technically incompetent to answer that question in any more depth. What surprises me, though, is your struggle with gain with 242 (or for that matter with any other tube) because I had the exactly opposite problem! I am sure that if you send the DAC back, they can match the output levels to your preamp, which in my case has done wonders....for e.g. I used to get the problem of oversaturation, at times, on PX4 with the preamp adjusted down by -6db!!. All that's gone now.
I have no issues of hum at all with DSD 256....but I don't have the DSD 512 engine. So maybe not the right person to comment.
I hope I have been of some help
Brgds
Sujay
I had no opportunity to compare and made a blind choice - PX4.As said above any tube roll after the 101d is a massive change
Let us know what you think and why.
Post your thoughts plesee
