Hi Blizz,
I did not mean it was a myth. Just trying to understand how much it influences the final sound of the DAC. If it very substantially influences the sound, then all us GG'ers are in for an amazing treat.
I was looking at Bughead the other day and there is a mode that actually introduces jitter to increase bass? Any ideas?
Based on my experiments with my chipless DAC, it's drastic going up to a better USB interface chip and clock. But I was unsatisfied with all the turn key OEM boards and went 100% custom with the XMOS Xcore 200 chip.
I have no idea what that does. I played around with it, and when I realized it's just special effects software, I uninstalled. I like my audio pure and untouched.
What is your opinion on external clocks like esoteric, dcs and the like use?
Like I said before, you can usually get better results with a higher jitter clock located close to the DAC chip inside the DAC case. or chipless DSD low pass filters, than using a much lower jitter external clock. This is because the jitter specs are no longer that great by the time it runs through the cable and connectors, to the DAC chip. But it is a big money maker, as they can sell you another expensive box. They just have to ensure that the built in clocks are mediocre, so a big difference is experienced when you connect the external.
I saw a company called audiocom who mod oppo with a 37 femto second clock for the audio board. How much would a clock of this quality cost and how much better can clocks get than 37 femto seconds? Could one install these into a USB interface easily?
This whole "Femto second" talk is a bunch of BS. It's referring to a spec that's so far out of the audio range that it's irrelevant. But it sounds better because they can use the word "Femto". It's purely for marketing. What really matters for audible jitter for audio is the 10 and 1hz phase noise spec. A plot like I posted is what's required to know this. And also keep in mind even very good clocks can be +- 15db of phase noise from the published spec, so I wouldn't buy a clock that doesn't come certified as individually tested, with the phase noise plot of the actual clock you're buying.
I like music, and I can not go hear it live all the time, so at a young age I found out there was recorded music. I liked it. And, through experimentation I found out that music can sound better and louder over a larger speaker system and then I bought larger stuff, and I found out that in the analog world, the stylus, a little bit the actual TT, the source of music (lp, 45, digital, tape, radio) and other components all added their own sound to some extent. That led to trying to find stuff that sounded better to me.
That led to learning electronics and experimenting with audio circuits, and that led to an understanding that you can make audio sound any way you want to, but if you wanted to hear what the master engineer decided he wanted you to hear, you needed electronic accuracy. That led to accuracy for all electronics as best I could by looking at some measurments and learning about others that are not the standard published ones. That lead to understanding of accuracy.
Then, that lead to a balanced choice of components based on measurments where they mattered and on sound too(primarily the amp and speaker and room interface) and led to a system meeting my preferences.
That led to my purposeful manipulation of the sound for effects and variety, for example SET sound and headphone sound. I decide what "sound" I want to hear, and then by gosh I choose those components or speakers or headphones and electronics that deliver that. But at no point do I expect any thing about a real experience or replication of a live event, just sound that I like, and for me, that means detail retrieveal and dynamics, and I prefer to listen to music that had dynamics and has clear detail in the recordings.
And, as I like to listen to music, I come here to find out what other folks are listening to (thanks guys) and also to discuss the technical state of the hobby, but knowing damn well what the limitations are, and by accepting them, overcoming them.
We must separate stridency or edginess existing in real conditions of listening from the stridency or edginess due to poor sound reproduction. IMHO they sound quite different.
I have listened live several times to Stravinsky Petrouchka and Shostakovitch Symphonies, they are violent and powerful, but never edgy or harsh - at less 15 meters away from the Orchestra. It is something that most of the time separates real from reproduced - it sounds powerful but not excessively loud.
I have listened to many syrupy and strident systems, but fortunately also to many systems that have an nice equilibrium between them. I will not write in name of audiophiles, but I disagree on your paternalistic and confessional "we, audiophiles".
BTW, we should also separate sounding realistic (usually used as meaning a facsimile of reality) from using the sound of real acoustic instruments as a reference. Most of the time we are debating semantics.
Let's not confuse SOTA with SOTA ...
vinyl reproduction remains a moving target, even at any so called SOTA level. And here is the kicker ... if your turntable is truly "sota", then rip it and let the rest of the world appreciate ...
Okay ta. Could you point me in the direction of a clock that would be sota? Not that I can get Lampi to agree to all this but can ask.
Well the crystek 957 is a good readily available clock. Much better NDK's are available, but long lead time and minimum order quantities. All the best TCXO's are like that. Clocks are like precious gems, no 2 are the same, so they must be sorted and tested in order to really know the spec. For example, I'm only going to use the top 5% of a reel of 500 in my DAC's. Each one must be tested on a $100000 machine, and it's takes 2 hours to test each one! So I must buy a reel of 500 just to get 25 clocks. And I also have to pay to get all 500 tested and sorted. It's not cheap, and very few do this. But I want every DAC to sound identical.
Thanks. I also noticed that some of the diy brigade heavily shield these as they are very noisy?
Lets put it this way, say you are in a rectangular building, and at the opposite end is a band playing and you are listening at the opposite end say 125 feet away. The sound you hear there at that point could sound similar to what you stereo system shows you because all the diffusion and delay and homogenization of the sound (your two speakers can put out this sort of soundfield), but as you progress closer and closer to the live event you will hear why stereo just can not do it.....its just the physics of the thing.....and while it can do it at a distance in my example, it cant do it up close....
I was struck by the 'warmness' and 'roundedness' of the acoustic, and I suspect the conductor hears something slightly less 'warm' - as has been mentioned, brass close up can sound harsh or positively distorted.
I know that what we hear in many recordings is different from the real thing: multiple microphones close to the instruments all mixed together with a dash of 'ambient' mic thrown in, but each microphone's output is individually linear and 'valid'. Mix them altogether and our brains simply accept it as an arrangement of instruments in an acoustic. Stereo from speakers isn't correct, because both ears hear both speakers anyway, but we are adept at filtering out the error. The upshot, for me, is that it works amazingly well and is a pretty good substitute for the real thing. In fact, I think it is superior much of the time simply because it provides 'the best seat in the house' - even if that seat doesn't really exist.
Agin why do you think warmth is an artificil additon? At the same time most never regard cold and sterile as such.I agree in principle. In a sense a good multi-miked recording really is 'the best seat in the house'. If I remember correctly, when the famous conductor Herbert von Karajan was once asked if a live concert is not the best, rather than a recording, he answered "For whom?". Yet I wouldn't want to miss regular live concerts, both for the experience and the reference of the real thing.
Warmth is indeed often, though not always, heard in the concert hall. Yet I agree, I wouldn't want that artificially added in the recording either. The timbre should not reflect any particular seat in the hall as if it would 'replicate an original event' (impossible), it should sound believable within the wide range of timbres heard in live settings.
Ideally we make the best product we can an pick our poison.
Digital distortions are orders of magnitude lower than analog. And in some cases such as frequency response, non-existent. There is no equality there. Analog distortions can be easily demonstrated and proven to degrade the original signal in audible ways. Not so with digital. Even when we degrade digital with lossy compression, vasts majority of people have a hard time hearing those. We all however hear analog distortions such as increased noise floor, change of frequency response, etc.Sigh it's like quicksand the more I struggle the deeper I get sucked im.
I think the topic in this thread is analogue warmth.
Solid Stae and digital have thier own distortions. Tube vinyl have thier own sidstortions. Bith have their attributes. So do the advantages contribute to the illusion of realism(musciality ) or distract from it. etc. Of course all music is analogue. The fact of the matter is that sterile and cold are attributable to certain types of devices . Many people want to equate cold and.steril to accurate and neutral. I feel sorry for you if you fall for it. You can walk to light any time you wish.
I enjoy hours of my digital music experience. If something is sterile, it is in the recording. It is not because it is digital.
The only illusion to not fall for is thinking a less accurate recording process like analog, is more accurate at the end.
