I have spoken at length with the importer here. We elected to leave the speakers out for the moment, and focus on the new Robert Kodas, the signal ground incl the sub. Dual Plutons, an Olympus Infinity and all the cables and Peak 4s which run with that is quite a commitment. It allows every component or signal to have its own dedicated grounding unit to itself...PLUS a double-set of grounding units for each of the monos.Are you going to try it on your speakers?
Still baking in...but if it goes according to plan, then that will be the plan.
I have heard great feedback on grounding speakers, but not in the cards at the moment.
