Thank you, Tango. I wonder if anybody on WBF has compared these side-by-side with the NAT Magmas in the same system?
Servos control movement of cones nothing to do with blending of electronics which is a question of choices in any multi-amp setup.
david
Whilst In jeopardy of flogging a Dead Donkey here, We're I in your position Ron I would most certainly at least consider and look into the feasibility of a home demonstration of a pair of Atma-Sphere MA1's or MA2's, the practical advantages....being Manufactured In USA ergo no exchange rate headache, plus on shore servicing if required.
The technical advantages being.....no transformer saturation to take into consideration especially as high voltage/ output transmitting valves generally require ever larger Mains and OPT which bring their own set of problems, 'Genuine ' Class A operation with invariably lower distortion levels at 50-100% output over most if not all SET topology.
The subjective/ no empirical evidence as yet measured advantages being......Most likely a more Linear response from your 200Hz crossover point and upwards, and perhaps particularly in that crucial 100Hz > 200Hz range when handing over to the also most likely linear SS driven actives increasing the chances of a smoother transition from Valve to SS Amplication.
In the main, one of the appealing strengths of an OTL topology is also one of Liquid and Texturally satisfying midrange tonality.
I hope that you remember my PayPal account details Ralph![]()
It seems like we are talking past each other here. As always, it is about one's sonic priorities and sonic sensitivities. Someone who is very sensitive to the sound of different amplifier topologies on a bi-amped speaker is going to prefer to use the same amplifier to drive both stages of each speaker.
For others the sonic gains from using different amplifier topologies to achieve the sonic priorities desired (e.g., sweeter, more "liquid" midrange) will outweigh any sonic detriment arising from dissimilar amplifier topologies.
The servo control of the bass can probably impose its sonic sound signature over that of the amplifier, making the system less sensitive to amplifier choice. But I am guessing, only Gary could enlighten us.
we can all have an opinion or guess on how this might work. but I live with this approach, and it's awesome and the best bass integration I've yet heard anywhere.
You’re using solid state, ie similar amps in the entire system Mike integration isn’t a problem in your scenario the debate is over mixing dissimilar amps, SETs or tubes in general with solid state in the same system vs using same type amps like you’re doing.
david
Ron,
I just spent a few minutes on the Gryphon website studying the Pendragon details. I was trying to understand exactly the interface between the bass tower signal path and the main tower signal path. I was not able to determine where the bass towers receive their signal. it only describes a separate active crossover for each bass tower; but it is not disclosed where the signal for the bass towers is received.
do they take the signal from the main tower speaker terminal?
or do they take it from your preamp?
my question is; whether the character of the amps for the main passive towers with the Pendragon are part of the signal source for the bass towers?
with my Evolution Acoustics MM7's; the active bass towers take their signal from the speaker terminals of the main towers; which allows the character of whatever amplifier is used to be mimicked by the bass tower amps. which allows for a seamless character between the two towers in the bass. I've had a few tubed amplifiers in my system and never had a discontinuity in the bass related to different topographies.
if the Pendragon does get it's signal from the main tower speaker terminals, then the integration will be done for you already regardless of the amp you choose for the main towers.
Ron,
With my Evolution Acoustics MM7's; the active bass towers take their signal from the speaker terminals of the main towers; which allows the character of whatever amplifier is used to be mimicked by the bass tower amps. which allows for a seamless character between the two towers in the bass. I've had a few tubed amplifiers in my system and never had a discontinuity in the bass related to different topographies.
We can all have an opinion or guess on how this might work. but I live with this approach, and it's awesome and the best bass integration I've yet heard anywhere.
I emailed NAT Audio for a wattage vs distortion graph. Will let the forum know if they accommodate. The only measurements online for this company are for a preamplifier.
Sometimes I wonder if people would just prefer to speculate all day and spin their wheels rather than using hard information as a guide. Good grief!
