We have been in lockdown in Melbourne again. Since I have not been able to get out and visit or have friends over, I have gotten busy and done many of the little DIY projects that have been on the back burner.
Firstly I have refined the speaker crossover further:
There's not much difference in the measured response, but it sounds quite a bit better.
I did some upgrades on my CD player which uses an Arcam Alpha as the transport, but has a NOS DAC board designed by Chris Bryant in the UK. The DAC board already had copper heatsinks and NX Black Gate decoupling caps round the 1541, but I upgrade the bridge diodes to ultrafasts, and change the DAC chip to a single crown. The Transport part was stock from the 90's and was struggling to play many discs, so it was time for a recap. Rather than modify my already working unit, I bought another Arcam Alpha, which I recapped, changed the 7805 heatsink to copper, added a clock module and the bridge diodes to ultrafast. The machine sounded better and now has no problem playing discs. I also can't get over how bright the display is.
Next up was to replace the lids on the power supplies for the field coils. I bought some perforated perspex sheets from RS and measured up and cut the lids out.
The supplies to the wideband Supravoxes are critical, so I wanted to try some mods to them. They are Chinese made regulated linear supplies, and I just changed the power supply diodes over to ultrafasts and changed the heatsinks over from aluminum to copper. I still have to figure out how to make some non metallic lids for these.
Surprisingly the mods to these were very audible ans better dynamics and greater purity in the mids.
Next up was a suggestion from another field coil user, Ralph Karsten from
@Atmasphere amplifiers. Ralph said that he had found the gauge of the wire from the power supplies to the field coils to be critical, and the larger the better. The wires I had were pretty thin, so I made up some really beefy ones from Cat5 cables. Also with the bass supplies, I connected them to the back terminals of the supplies which provide higher current output.
Final item was to connect up a dedicated earth to my isolation transformer which I have always had in the system, but with just the standard earth. Rather than putting copper poles in the back garden, I just connected a thick copper wire up to the hot water pipe under the kitchen sink.
Now I have to think what else I can do for the rest of this lockdown.
