Hi, I've bought from a thrift store two Warfedale 506 speakers. I checked everything looked fine.
However at the store I overlooked that one of the binding posts (where the speaker wire is attached with a plug)
was broken of. Probably I saw three plugs/posts on the terminals that were allright, the fourth must have been hidden by a bundle of old speaker wire that was hanging over it. So I didn't see it untill I got home.
I did not discover parts that were broken off in my car so it must have been broken already in the shop.
However...I want to fix it....how can I get into this speaker? I don't see screws in the housing to get inside.
I never done this but want to try...the speakers didn't cost that much so I don't need an expensive repair.
So would like to try myself. Can I lift the small terminal? or should I get into the speaker by lifting something
like the woofer? How can I do this?
They say the woofer has a bajonet ring that has to go a bit to the left by sticking a screwdriver in one of the square little holes,
and then ticking it to the left so the woofer comes off ( I cant do it yet, it doesn't budge) tips anyone?
