What are you trying to accomplish with this server? The Lynx card is nice for multi-channel if you also have a multi-channel DAC or multiple DACs and you are okay with using jriver volume control.
There are some other cheaper multi-channel cards out there. I once had a HTPC with Asus multi channel card. It worked pretty okay. You could try
this one with the xonar hdav 1.3. If you are going directly to a multi-channel amp, be really careful with volume control.
When I did this, I used a
parasound p7.
Using the xonar multi channel soundcards with the parasound p7 was the closest I ever got to making a PC a true Pre/Pro. I could get true lossless decoding for blurays, etc. That was the last multi-channel system I had. I just couldn't be happy with 2 channel in that system. But if you are not interested in using this setup for 2 channel, I would recommend the xonar cards with an external multi-channel volume control like the parasound. You could also use jriver's volume control, but you could run into problems when you do things like reboot your computer with no protection between your computer and amps; it could get ugly.
You could also use a lynx 2b card. I tried that once as well. My problem with that setup was that I couldn't get true lossless decoding for bluray. Maybe there's a way around that now; I doubt it though.
The other option is simply getting an oppo 103 or 105. The new Oppo has hdmi input. You should be able to use the oppo as a very high quality pre/pro and just use a computer as the server, in which case you don't need any sound card and you WILL get outstanding sound quality; maybe even good enough for 2 channel. If i were undertaking this project, that's what I would do.
Hi
I hope I am not sidetracking the ongoing discussions. I am interested to experiment with an HTPC but would like it to remain low cost. In that spirit are there low-cost but decent sounding alternatives to the Lynx AES 16? Would like to try my hand on the HTPC and move on later to better bulits. I am not even convinced that an i7 processor is necessary in this context but I could be wrong. I am planning to use a small SSD (32 or 40 GB) for OS and maybe a music cache and eSATA or Ethernet HDD or NAS. JRMC of course and all other software in this thread. What say you?
