I know the history. But I don't see many other similarities.
I have/had both and I know which I prefer IMS
Try the reissued Ivan Moravec piano recordings originally on Connoisseur Society produced by Alan Silver and recorded by David Jones (Waltz for Debby).
Hi Myles...thanks. i could only find on vinyl. Does this one work? http://www.amazon.com/Window-Time-R...62890&sr=1-3-spell&keywords=bosendorfer+pinao
it is a Bosendorfer piano roll of Rachmaninoff...or is this not the Bosendorfer with the extra keys you were referring to?
These are wonderful performances and sound, at least on vinyl and are from his Connoisseur Society recordings. They were released on CD, but maybe are OOP????
http://www.amazon.com/Connoisseur-Society-Debussy-Moravec-Piano/dp/B0036BU0DM
The best might be to look up Vai Audio.
I think this one is equivalent to the Beethoven above:
http://www.amazon.com/Ivan-Moravec-Plays-Beethoven-Ludwig/dp/B00005YP1W/ref=pd_sim_sbs_m_1
This is one of my favorites (what gives on the price though?):
http://www.amazon.com/IVAN-MORAVEC-...8-2&keywords=ivan+moravec+connoisseur+society
I think Transparent and MIT are very different animals. The TA "boxes" simply limit bandwidth, in a very similar way to the Audioquest dba system, but of course, using different methods.
I just watched a 20 minute video on MIT's site, and it was filled with theory and what I like to call
invented problems. Manufacturers like to invent problems, especially in high end audio, so they can create and sell "solutions". There half a dozen branded pseudo scientific terms like Fractional Articulation Technology
I also naturally dislike companies that churn their line non stop. Shunyata does this too. Every year there is an overhaul, with promises of "breakthroughs".
I mean I just had to laugh at their new MIT "Super HD" line.
ALL that being said, I have only heard and seen them at shows, and I am sure they sound great other wise they would not have been paired with insanely expensive speakers and components.
Andre do you truly believe all TA does is roll off the top end? That's far from my experience when I spoke with Jack
Hey Myles:
I truly do not know. Based on listening, they are better than just about every cable I have tried for specific applications.
I believe they state their aim is to limit bandwidth.
This is what many cable designers have aimed for..to create some sort of shield, whether it be with an active charge, a simple network, a fuse!, or a battery.
I think you are confusing some things or I’m confused. Audioquest’s use of the DBS system is to “speed” up the signal flow if you read their literature, not to limit bandwidth. And shielding a cable does not reduce the cable’s bandwidth. Using a network like MIT does for say Spectral amps definitely does reduce the bandwidth the amplifier sees in order to prevent the amp from going into oscillation due to its extremely high bandwidth.
Hey Myles:
True about the MIT. But I thought the DBS thing was to reduce noise picked up by the cable? Not sure how this speeds up things.
I just went to the Audioquest site and read about how insulation slows the speed of electron flow or some such nonsense which causes all types of errors that Audioquest fixes for you with their charged cables.
Mep,
Could you supply us the link where you read such horrible nonsenses? Although I do not believe that it is possible to explain exactly why DBS returns audible benefits in sound reproduction using our current knowledge, I have read an interview with Bill Low of Audioquest about DBS and he never referred to such nonsense as "speed of the electron flow". BTW, please remember that the DBS technique is being used in the capacitors of crossovers of the great JBL DD6600 - it is why it needs so many 9V batteries. Applying DC to create a stationary permanent polarization to a dielectric to reduce its intrinsic noise is not properly new - using it in cables with a particular geometry was. It is why it was patented:
http://www.google.com/patents?id=wix7AAAAEBAJ&printsec=frontcover&dq=7,126,055&hl=en&sa=X&ei=dqjfT5uIEcaX1AWHzpWGCg&sqi=2&ved=0CDUQ6AEwAA
Although there are many people who are not reasonable with their claims, I have found that Bill Low is one of the very reasonable guys. You can find some of his opinions at PositiveFeedback
http://www.positive-feedback.com/Issue18/audioquestinterview.htm
Disclaimer - I have used Audioquest cables - the silver Sterling III and Lapiz III, about twenty years ago!
Here are the exact words, I didn't make them up:
DIELECTRIC-BIAS SYSTEM (DBS, US Pat #s 7,126,055 & 7,872,195 B1): All insulation slows down the signal on the conductor inside. When insulation is unbiased, it slows down parts of the signal differently, a big problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes both energy storage in the insulation and the multiple nonlinear time-delays that occur. Sound appears from a surprisingly black background with unexpected detail and dynamic contrast. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check
Here is the link:http://www.audioquest.com/reference-series/wel-signature
