Don-The main reason I wrote the positive statement that I do believe in power cords is the fact that with the new power cord, the racket my huge power transformer use to make is gone. Krell recommends having a dedicated 20A outlet for the KSA-250 and I do. I was feeding the Krell with a wimpy, er, I mean an excellent up to the task 12-14 gauge power cord. When I installed the new 7 gauge power cord-boom, the noise is gone. Now is that because the new power cord is very well shielded or is it because it can draw much more current from the wall due to it being 7 gauge or is it a combination of both? I really don't think the transformer mechanical noise is going to go away due to "wiper action" of removing and installing a new power cord.
Hi Mark,
I want to be clear that I am not questioning your results; I am curious and thus speculating about the cause. As I said, I have seen benefits with power cord changes, but rarely. I like the idea that there was a very obvious benefit in your case. Treat my posts on the subject as the idle musings of an old fart.
If there was oxidation causing poor contact at the either end then it could explain this. If there were some sort of interfering signal that the new power cord is filtering that could also be a factor. If the previous cable was defective or had a poor ground, that could explain it (in the past I have run across more defective cords than I would have imagined, very often a bad connection on the ground or neutral so it wsa not obvious the cable was defective). A standard 20-A line means 12 AWG cable to the receptacle, at least in CO, so I am skeptical the increased gauge mattered, assuming you plugged it straight into the wall. I do not question your results, I am just musing out loud about what might have caused them. A cord that eliminates power transformer hum is an interesting challenge. Transformer hum can be caused by unbalanced lines, poor grounding, or (severe) RFI, among other things; a new power cord replacing a defective cord could solve the first two, and if it included filtering would help the latter.
Curious: Do some power cords include in-line (series) capacitors to block DC offsets on the line? A DC offset could certainly cause the transformer to buzz.
I suppose a stretch idea would be moving the amp whilst installing the chord changed the way the transformer was sitting so it is better isolated (e.g. hung up on a mounting bolt so the little isolation bumpers did not work and moving it freed the mount) or dislodged a wayward component that was pressed against the transformer...
No worries, just curiosity and idle speculation - Don
