Drum roll...isolation off, isolation passive, isolation active.
Much to my chagrin, when active is engaged, the sound is deadened, less open and airy. It sounds best with the unit on and only in passive mode (active off). Bummer !!!
It was easy to hear and David confirms my findings...
David was right.
Merry Christmas, Christian. Could you please clarify something? When you turn the active isolation off, does that mean the table acts as a solid, rigid structure as if were simply a welded steel framed support, or are there some passive springs still in effect somewhere? In other words, are the Herzan isolators, active and passive, completely removed from the equation and it is now as if the turntable is on the same type of support that David uses?
