Hello Guys,
I am pretty happy with my audio system containing the below:
Speakers: Spendor A7
Amp: Hegel H190
DAC: Topping D90SE
Sources: Nuprime CDT-8 Pto and Nuprime Stream 9
As I learned, the Topping DAC performes quite well as a preamp connected to the Hegel, using its HT bypass.
This made me think to replace my Hegel for some better sounding power amp or set of monoblocks.
I would like an airy, open, natural sound with well controlled and accurate bass. Also something pretty revealing, but not being on analytical side.
My budget is around 4K USD. I will try to audition Benchmark AHB2 and Nuprime ST10M monoblocks, as the reviews suggest something I might like.
Any other ideas will be much appreciated
Also, do you think I can get big improvement over my Hegel within my budget? Or is it better to save up?
Kind Regards
Amp: Hegel H190
DAC: Topping D90SE
Kind Regards
