The sound of SilentPower. We are introducing the new additions to our SilentPower Range, SupaNova & Nova - Our all-new power cables.
Most power-conditioning products engage passive noise reduction through a selection of filters and regulators. While this can be effective, it has inherent disadvantages. Passive noise reduction systems are effective at the top end of the frequency spectrum but often less so at lower frequencies. In addition, passive systems need large capacitors to be truly effective, which make the best such products bulky and expensive.
iFi’s active system uses inverse noise current to cancel out the noise in the mains signal. Noise in the mains supply occurs at different frequencies, depending on the cause. Active Noise Cancellation II technology enables a power-conditioning device that is highly effective at reducing noise consistently across the entire frequency spectrum yet sufficiently compact and lightweight to position within the mains cable itself.
Nova by iFi audio - The affordable high-performance mains cable.
Specialised high-end construction Our specialised power cable delivers a serious upgrade over standard mains leads and imbues sound with greater clarity, space and definition.
ifi-audio.com
SupaNova by iFi audio - Our multi-faceted active power cable eradicates dirty mains power and add clarity to your sound.
Noise busting, high-end perfornamce. Our multi-faceted active power cable cleans up dirty mains power and adds clarity to your favourites tunes.
ifi-audio.com
