...it probably does sound good, but it's power cable stock... that is, for making power cables for component terminations, based on their info sheet.
So, that would be analogous to taking an extension cord and running it from your panel, through your joists, walls, etc. and to an outlet. Sure, it's an excellent extension cord, but it's not rated for use in wall, as far as I can see.
Many things *can* be done, and if nothing goes wrong, it seems like a good idea. But, wow if something does go wrong...
I use 25mt of solid core OYAIDE EE / F-S2.6 V2 Power cable 102 SSC copper FEP shielded 3x5.3mm². It runs from meter to back of my audio system. A little pricey but very smooth and silky sounding cable with good dynamics.
Hi sir MarkusBarkus and Mtemur, It's me, the Hanoi Vietnam guy who got your advices from the "Dedicated AC Line For Hi-Fi Setup" thread.
I've been using dedicated Gigawatt LC-Y inwall cable for about six month now, with about 1.5ohm grounding resistance.
Since moving from old 20 year-old-apartment with cheap standard inwall cable and common grounding to this new house with these fancy in wall cable, I now understand that the problem with our city's polluted electrical line cannot simply be solved by a nice dedicated line.
Reason I say this is because my system is still unhearable when the grid is not clean (music sounds lifeless, mid gets colder, treble harsher, subbass not dig deep,...) and that means most of the time, so same problem with my old apartment with standard wiring and standard grounding.
But I would say that, the good thing about this gigawatt dedicated line is that it helps dissipate the noise better, compare to the old wiring in my old apartment. And it shows its greatest strength through a piece of equipment that I put in the corner unused in my old place, because I tried and thought it was useless, the LP-11 UPS online with isolation transformer from GE.
Now with the dedicated line and the GE LP-11, the grid gets less dirty, music becomes bearable more often, and when the grid noise gets too bad that even the ups cannot clean up, I switch to its battery mode using lead battery, and the sounds become listenable again.
Althought I am not sure the difference when utilizing this ups online is contributed by the dedicated line or the 1.5 ohm resistance seperated grounding or both. But I know one thing for sure this combo (dedicated line and good grounding) does wonder to reduce the noise, hence the noise is cleaned up better after the ups (compare to the old apartment).
Another experience with clean electricity I got is from the place I work, which is a factory 25km away from Hanoi, but it is actually 25km closer to the Hydroelectricity dam that provides power for the whole north area of our country (the factory is only about 30km away from this dam, Hanoi is 55km away). This factory is located in an industrial zone, the power is 3 phase, and my factory has this transformer built that costs about 50k usd that also does some sort of AC - DC - AC convertion, balanced iso trans (hey, kinda same as my ups online but much much bigger), and compensate power, turning 3 phase power into 1 phase.
The factory only use standard cheap in-wall cable, and about 10ohm of grounding resistance. But I experince clean electric quite often when I am at the factory, and that was during working hour (which means the whole area's industrial machines all working with all the noise get into the grid).
All I have to do is to use a diy electric distributer with emerson AC filter (cost about 100usd) as power source, and the headphones +dac/amp sounds fabulous.
So, If I live in this factory, I might as well not need a dedicated line and good grounding I suppose.
