That is actually strange, they are a pretty tight fit, did you replace the batteries with a different type?
This is with the supplied Duracell battery...
As a guy who plays as much on the dark side as in the light I am more than happy to explore both the known and the unknown. I’m genuinely never going to be ripping the shot out of tweaks generically rather than just to say that small things can have an effect on the system or the room or us and that not all of these things need to be obvious to then (synergistically) also add change to the experience. To try and to reflect is good and also just cause you like it doesn’t make it objectively better but can make it subjectively preferable.Is this a spoof thread? No disrespect guys, I've had the $hit ripped out of me when I revealed that I replaced 9 stock fuses in my preamp alone w SRs, and believe in directionality, and have installed a specialist pwr cord on my tt motor psu.
I'm just wondering about this one. Otoh, I know someone who has dozens of crystals in his system, incl on cbls, and is a firm believer in crystal directionality...and yes, battery power to some of these crystals.
Tao, when you meet a guy who has battery-pwrd crystals, SR room treatments OUTSIDE the listening room, and tweaks inside his FRIDGE...you learn to question nothing (or is that EVERYTHING?).
Hello,
No,I’m using it with Jeff Rowland Aeris DAC connected with Cardas Clear BNC.
Regards.
IC
Then please try the La Diva with the Formula xHD dac.
(But DO NOT use the I2S cable included with La Diva. Get a better ethernet cable.)
This combo had surprised me!
I am happy and surprised
Just change the lithium 9V batteries for D2s and A2 for a few days.Eventually my frd and I got the Energizer lithium 9V battery!
How does it compare to Energizer alkaline 9V battery on Setchi?
I guess I may be talking too much on WBF for such a cheap tweak.
The Energizer lithium 9V battery is only usd8 per piece.
Pls buy one and try it yourselves.
You will be very happy!
Hello Emile,We have switched the default fitted battery to the Duracell Industrial Professional series:
Hello Emile,
A frd of mine in HK bought a new Setchi a few days ago.
It was loaded with this Duracell Industrial alkaline battery.
He said that it was very very close to the Energizer Lithium battery.
Thanks for your care!
You always respond quickly to feedbacks from customers.
