All else being equal an integrated will easily best separates - the latter immediately introduces a whole set of weaknesses which will then "colour" the sound; which may be to some people's preference, of course.
Doesn't a manufacturer stand to generate significantly more revenue by keeping the chassis' separate?
The problem I see with integrated amps is the speaker cable limitation.
Its often a very good idea to keep your speaker cables short. This is particularly true if you speakers are low impedance. Longer speaker cables often tend to smear detail. I've had this demonstrated in spades! This could limit how far apart the speakers can be set up. IME if you have good resolution, its advantageous to get the speakers further apart so you don't have the 'miniature musician' syndrome.
If the amp is an integrated then you have to keep it between the speakers in order to run shorter runs. That's not always the best place in the room for an amp. So it can be advantageous to run separates so the speaker cable can be kept short for best results. I run balanced lines between the preamp and amps, so essentially its as if the interconnect cables don't exist, as far as the system sound goes.
Another issue with integrated equipment is of course the power supply. If shared between channels and/or preamp section the result can be noise, which will manifest as higher distortion, reduced separation and loss of bass impact.
This latter issue can be overcome with proper design and construction.
. . . That 'hump' is the fact that most a'philes, including myself, believe that a great pair of separates still sound better. This really should not be the case in theory....the integrated can/ could just as easily encompass of all the same parts and quality as the greatest separates, and yet it can enjoy far shorter signal paths and do away with the connection that is required between amp and preamp....IOW...the interconnect cable. So, why is it that the integrated amp is still not of the very first category as to SQ and is still considered as the 'step child' in audio...??
There has certainly been a significant number of new high/highish integrated amps coming on to the market in recent months from a number of respected manufacturers.
I think a lot of people are baulking at the box count with separates and finding very good sound quality from the new range of integrateds.
If you have a number of sources pre/power/separate power supplies really need a dedicated listening room which is not an option for many people and even if it is the extra number of boxes and expense can be an issue.
I was a holdout for many years. I had a full Naim set up. When we moved to our current house I decided that it was time to change my system out. I traded out of my Naim set up and after testing ended up with the Boulder 865. I might have bought the Vitus SIA 025 if I had heard it before I bought the Boulder. I was considering an arc ref 40 with Boulder 1060 or the Boulder 1010/1060 combo. I went to my dealer and asked to compare the 865 with the 1010/1060. Was the 1000 series better? A little bit, but with my speakers (Wilton's) and cabling the 865 was truly 90% of the way there or even 95%. I felt the Boulder was just amazing and went with it. I had a chance to hear the Vitus RD 100 and fell in love. If Vitus had an S series dac/preamp I would have tried that. I tested it with the Boulder 865 and was truly over the moon. This set up replaced the Naim ndx, 555ps, Naim dac, unitiserve. The Vitus was transformational. I am even considering the SIA 025 although i should probably live with the Boulder a bit longer. I have considered upgraded the Boulder to a 1060 but right now I am happy. The integrated is great, bested the Naim and is on par with some of the best separate systems I have heard. To go to the next level, it's serious money!
Not dissimilar from my experience.
I went for the SIA 025 and its a real star.
They do come up for sale used.
Ralph, do you feel that there is also additional value in purely just the physical separation between pre and amp in terms of better mechanical isolation and minimising electrical rfi noise.
I'm pretty sure there is a tradeoff there. With an integrated you don't have interconnection issues. So there should be less RFI potential. Its really more basic issues that seem to limit integrated equipment- there is too much temptation to share power transformers and power supplies and its easy with the increased complexity that results to not optimize the grounding and power nodes.
In our amps we found that if we made the driver power supply operate with a separate power transformer, the result was much reduced IMD. Since we already have a separate filament transformer from the B+ transformer, you can see that if we were to build an integrated amp and not skimp, the result might be that there would be 6 power transformers! Now we could combine the filament circuits without compromising anything; and maybe that is true of the driver supply as well. But if one channel can talk to the other for whatever reason through the power transformer, we will have increased crosstalk and likely higher IMD (which is very audible to the human ear). Its the latter that should be on the radar of anyone who wants the most out of their gear and is why separates have been around since the 1950s.
I got an Integrated for its simplicity. The wife wanted something where she could just press one button and just listen. I opted for the Parasound Integrated which is a full function pre and included DAC. She, nor I, could be more happy with its performance. Has plenty of power to drive the Maggies and the tone from a Ray Brown bass is to die for!
