Hopefully you are not attributing that statement to me. Although for some circuit designs in some systems that is probably true. Not the rule IME.
A quotation from Thrax the manufacturer in a Mono and Stereo article:
[snip]
Triodes are indeed some of the most linear devices around, and as Don points out, so are some of the MOSFETs and FETs. The high distortion of an SET is something that really should not be experienced if set up right (if you will pardon the pun- 'set' up right??)... which most are not. You really are not hearing what an SET does unless the speaker has enough efficiency to prevent you from ever needing more than about 20% of full power. This really keeps the distortion and especially the higher orders in check!
I wonder why nobody has made a single-ended pure class-A amplifier using transistors? A big power FET would seem a good candidate to compete favorably with SET amps. Not enough market demand, doesn't have the tube mystic,...?
There is a section on DIYAudio.com devoted to Nelson's DIY works.I wonder why nobody has made a single-ended pure class-A amplifier using transistors? A big power FET would seem a good candidate to compete favorably with SET amps. Not enough market demand, doesn't have the tube mystic,...?
Wow, those are pricey little buggers!
JFETs are a good choice for input devices; much, much lower LF (1/f) noise than MOSFETs. I see he's using VFETs; ironically, I "discovered" VFETs in a (Siliconix, I think) catalog and used them in a couple of amplifier designs.
