Hello,I just got Inito 3 and it is still in burn-in period, but I want to ask what specification the fuse has. I would like to upgrade it, and not really sure what fuse to look for.
thank you
Good evening, know if it is possible to mount the jcat net xe on the Qnap 453d where I keep my music library with another 16,000 albums (flac, dsd, and some wave) then I pass everything to a sotm switch, from there the signal via cat7 goes to my pc streamer with a usb jcat output card which transfers the signal to the playback box XIII which transfers it via double st/st to the playback pdm 5 converter guaranteeing perfect galvanic isolation. I think if jcat net could be added to qnap it would greatly improve the usability of my library. Thanks in advance for your replyHello,
The fuse is 5x20mm., 2A slow blow.
Best regards,
Marcin
Hi Massimo,Good evening, know if it is possible to mount the jcat net xe on the Qnap 453d where I keep my music library with another 16,000 albums (flac, dsd, and some wave) then I pass everything to a sotm switch, from there the signal via cat7 goes to my pc streamer with a usb jcat output card which transfers the signal to the playback box XIII which transfers it via double st/st to the playback pdm 5 converter guaranteeing perfect galvanic isolation. I think if jcat net could be added to qnap it would greatly improve the usability of my library. Thanks in advance for your reply
Maximum66
Grazie per la tua rispostaCiao Massimo,
Sì, è possibile installare la scheda nel QNAP NAS. TS-453D dispone di uno slot di espansione PCI Express. La scheda funzionerà non appena la installi.
Distinti saluti,
Marcin
Master OCXO Clock Upgrade
Now available
? https://jcat.eu/product/master-ocxo-clock-module/
We have the measurements from the supplier of the oscillator.Do you have measurements of the phase noise spectra of this clock?
What are the values for Phase Noise@ 10Hz and Phase Noise@ 1Hz?We have the measurements from the supplier of the oscillator.
-110 dBc/Hz @ 10Hz offsetWhat are the values for Phase Noise@ 10Hz and Phase Noise@ 1Hz?
-80 dBc/Hz @ 1Hz offset
While phase noise parameters are important, they do not solely determine the sound quality to the extent that some might assume. We conducted experiments with various oscillators; one had a 2dB better phase noise, yet it sounded significantly worse. In our experience, the board's design, component selection, and power supply have a much more significant impact on achieving quality than solely focusing on oscillator phase noise parameters. Our Master OCXO Clock, powered by the OPTIMO 3 DUO, confidently competes with products priced above 5,000 EUR. We've conducted such comparisons.
Marcin
Yes, 10MHz is available.Can you supply the clock board with a custom frequency of 10 MHz?
