mep
I am with you on the LS50. Within their dynamic limitations, they are as good as any speaker one may have heard. Don't push them too hard. It is not really a matter of SPL, they can play loud, it is that past a certain point, I would put that above 95 dB they are no longer startling, they are merely good. Past 100 dB at 3 meter in a medium room ... You asking for much more they may have been designed for. I have not lived with them long enough to make a defintive asessment . Suffice to say, they will keep me happy until I get to a dedicated room.
I disagree with you however about the mass issue. While rigidity doesn't always equate mass. An heavy enclosure has the potential to kill unwanted vibration. As a matter of fact the "quietest" speakers I have heard are heavy, very heavy: Magico comes to mind but also Wilson X-2 and Rockport (Aquila or Ankaa? can't remember) to name those. What I think comes to play is the ability to reproduce live levels in the upper bass to lower midrange region, say from 100 Hz to 800 Hz. There had to be some compromises and those most 2-ways share. IF one were to take a speaker like the X-2 100 hz to 800 Hz is covered by large cones ( I believe the second woofer, the 13 inch get up there to 600 Hz according to some sources) with serious magnet (or otherwise) motors. In such designs the midrange drivers don't have to do bass so they are optimized to do midrange as well , as clean and as loud as it can be .. Same with most large 3-ways and up the critical 100 to 500 hz region is usually covered by dedicated and beefy driver or drivers...
The speaker is simply superb. Within what it design range it is the full equal to many speakers costing several times more and believe you me, I'm not speaking of $5K speakers ... I would like to write a review about this little marvel. Maybe in two months, I will be traveling and taking a relatively long ( >2 weeks) vacation something I haven't done for nearly 8 years. If anyone can audition these at home please do. The better the electronics the better they will sound. They are as revealing as they get. One of the best speakers around and that at any price. The demeaning and patronizing "for-its-price" doesn't apply. They are flat-out excellent. If the Kef Blades are designed as well .. They could be killers in the $30 to $100K speaker region .. No jokes
