Kharma DB9 S
Use your own ears and go for what you like best :)
Good luck :)
Espen L
Good luck :)
Espen L
Will do. Upload your dB9 D'Agostino playing Mahler's fifth (or something of similar nature) and I (and 999 other spectators) will listen. Our likes/dislikes will determine how good (or bad, or average) your system is on that particular song. The question here is whether one should (or should not) invest in a particular equipment. My point is: one should only invest if one likes it (as you said) AND if the public in general likes it (what's the point in buying and not be able to sell to the next guy down the road).
There are many variables that play in! Room / Source etc ... Take my advice now and use your own ears :) When it comes to you tube to other things, the source is not worthy speakers like Kharma Magico etc ... Loudspeakers in this class should have the best sources!
Espen L
Espen L
You seem to not understanding what I am saying. Upload with the very best source you have, very best cables, very best everything. Whatever you upload though, will not come close to Kharma Exquisite / Lamm ML3 combo. Which is fine. We are establishing the baseline with Kharma Exquisite / Lamm ML3. Mind you, Kharma Exquisite / Lamm ML3 sounds extraordinary through YT as well. Once you upload, we will be able to hear how FAR from this ideal sound you (and other systems, e.g. Kharma S7 Signature, dB7, Mini Exquisites, Kharma 3.2, etc.) are. We will be able to discern the best one among these systems (knowing perfectly well that none of these will approach Kharma Exquisite / ML3 $300,000 system). I claim that many owners hide behind subjectivity agenda. They sell to each other allegedly worthless (in terms of bang for the buck) equipment, when they could have much more capable system for a fraction of the cost. Here is the baseline sound: https://www.youtube.com/watch?v=GINQKJ-T9vY
Totally hopelessly through you tube! Sorry !
Espen L
So what? It will be equally hopeless for every system that yours compare to, will it not?
Same room and same source against each other , then you can compare and put two lines under the answer. everything else is mostly just a bad thing in my opinion!
But me about this.
Good luck with you tube comparison :)
Espen L
But me about this.
Espen L
Remember that many owners of the speaker XYZ upload recordings of their systems. What counts is the average. If a person pays for dB9 and use $200 cable, I don't think such person represents majority. We don't care if somebody uses D'Agostino and somebody uses T+A. If it is high-end, it is sufficient for comparison.
Majority of people that upload will have had decent setups, because as I said, majority of uploaders are audiophiles. If you trust your system, upload some songs. In doing so, you ca only gain (if you trust your system; if not, that's another story).
Still my opinion
But me about this.
Espen L
Reactions: Hamburger
Still my opinion
But me about this.
Espen L
It seems to me that you are afraid to publish your system on Youtube. There are 1000s of systems out there, some costing over 1 million. I think I know the reason: all new Kharma lower offerings (<= dB9) sound hard, all of them. Thus you are smart enough not to upload and expose weaknesses of your system (compared to much cheaper but extremely good sounding alternatives).
Got installed my preamplifier and power S250 from Dan D Agostino this weekend.
Playing fantastic straight from the box at Kharma DB9 S looks forward to the continuation :)
Espen L
Reactions: XV-1 and Hamburger
Espen,
Are you still keeping the Kharma DB9S ?
I saw your post not long ago in Dec 2020 as i am searching for all articles on Kharma DB9S, planning for an upgrade of speaker to either DB9S / DB11S or Wilson Alexia 2.
1 - My listening hall is 16ft x 26 ft, do you think it can accomodate DB11S ?
Will it be booming with excessive bass ?
2 - Is my current amplification enough to handle the DB9s/ DB11s ?
( Accuphase C2800 pre/ Luxman M900U power amp )
Thanks
Kenny Chin
Malaysia
Espen,
Thanks
Kenny Chin
Malaysia
Hi
I have upgraded to Kharma Midi. I have heard DB 11 and they play bigger with more bass than DB 9 but dB 11 are very large and they require a large living room. I really liked the DB 9 and guess you will be happy with them :)
Espen L
I am late to the party here, but I am told by a reputable dealer that Kharmas sound their best with dense/big sounding tube amplification which counterbalances their tendency to go lean. I have not heard that first-hand myself. What I heard when DB7-Ss driven by CH gear was absolutely spectacular. The best thing about that sound was its nearly hypnotic layering of the soundstage with sound lit from within. Still can't get over that sound :)) The front end was also CH. I did not try different genres though. I am a big fan of rock and always wondered how satisfied I would be when I am in the mood for something like Volbeat, when the recording is less than great. Please chime in, if you have any thoughts.
My experiences with Kharmas is with the DB-7s, DB-9s and the DB-11s that own. From my dealers rooms and show rooms, They have never sounded lean no matter what the amplification has been. Not sure where that would come from.
I have only heard them with Boulder SS amps, Pass Labs amps and my Block Audio Monos which are Class A for all but the most robust listening levels.
They might sound lean if you put a DB-7s into a very large room. If your dealer knows what he or she is doing, they will insure you choose the right model for your room. The DB-11S can fill a large room. Mine is over 4500 cubic feet.
Please listen and make up your own mind. Good luck and enjoy the process.
Reactions: bejewe and George K
That's good feedback. Thanks
