Thanks, Phil, especially for your recommendations. The KCPs are real keepers.
Great to hear, Tan.
Hi Myles,
I started a 100 ohms, but a I find that 250 ohms opens things up a bit more (less damping). Of course the damping fluid in the tonearm can affect the load you choose. Seems to me, loading isn't a static spec deal. It's very system dependent. I'm running 250 now, but I may reduce the load the 320 to see how that sounds.
I asked someone who did have the diamond cantilever option and he seemed to indicate that the stylus and cantilever are one piece.
Christian, what final loading value have you settled on?
Christian, the question that was raised in this conversation was that no one has actually ever seen an image that documents that the diamond cantilever and stylus are one and the same. But if true, this person felt it was a tremendous advantage.
It depends. When running my SS Pass XP-25, I Liked 250 or 320ohms. If I run my nuvistor tube headlamp...Allnic HA3000 into the mm inputs(47k) on the Allnic H5000 DHT, I run either 100 or 200 ohms. If I go direct coupled transformer input on the H5000, I have no Idea as there is no loading control. You just select your gain/turnover.
I just read how to calculate loading when going through a SUT, the other day. It's not that difficult. First you need to know the MM input loading which is 47,000 ohms on most phono stages. Then you need to know the amount of turns your SUT has. Since your SUT has 4 different turns ratios the loading will depend on which setting it's on. So once you have this info you can calculate the loading for each setting. First you divide the MM loading 47k by the turns ratio for example 40/1. Which will be 1175. Then divide that number by the turns ratio again and you get 29.375 ohms. So you basically you divide the MM input by the turns ratio squared. So if your H5000 has the same turns ratio's as my H3000, then the loading will be as follows. The +22 db setting is 13/1 turns ratio and therefor the loading is 278 ohms. The next setting up is +26 db, and has a 20/1 turns ratio, so the loading is 117.5 ohms. Next setting is +28 db, and has a 26/1 turns ratio, loading is 69.5 ohms. Then the highest setting is +32 db with a 40/1 turns ratio, loading is 29.3 ohms.
Not sure why they can't put that in the manual, but at least we know how to figure it out now.
It's hard to tell. The dark area at the end may be the reflection of the cart body. It would be nice to have one...
Hi Sean,
Could you put that in formula form? I'll owe you a keg!
I haven't run trans input much lately, but tonight I prefer 32dB gain or 29.3 ohms on the Coralstone.
If you look at the specs of the KCP from needle doctor, I think the recommended loading is 30 ohms.
I have seen and sold 4 units of Koetsus with the Diamond cantilever option, and from my own examination, I did take a very close look at the cantilevers/stylus assembly, as I was very curious based of my regional dealer's claim that it is cut from one piece and not joined, I have to say that they looked like they were cut from one piece. Plus the damaged diamond cantilever that I mentioned earlier here, it looked like that the stylus snapped off the edge of the cantilever and I did not see a hole in the cantilever where the stylus was snapped in and glued or anything like that.
