A pre-production teaser:can you share a photo of the oled display.
Same as on all other DACs in the lineup (H excluded)can you share a photo of the oled display.
I think you have it wrong. Running balancedI need some input from someone who understands the circuitry of the Horizon. It has come to my attention that while running Balanced (in which I do) it is not necessary for all 4 Pentodes to be the same. This is what I have been doing. So, theoretically I could run OS1's on the left bank while running SRS on the right bank. My confusion is understanding if the left bank is more important/critical and insert the pentodes of choice in that bank, or does it not matter?
NO, that is not correct. I spoke with Lukasz this morning and this is what he said: "The overall gain of the 2nd stage with 4 Pentodes is 1:1 so the type of tube does not change the signal level and the signal will not deteriorate by much.I think you have it wrong. Running balanced
you need same 4 tubes in the pentodes. If you run SE only the left bank is for SE. You can leave the right bank empty or put in any pentode you want. It was Ian who suggested that even running SE the tubes in the right bank have a 10% influence on the sound. I found that to be meaningful as I prefer the right bank filled with KT 170 in the right bank. I did try a set of OS1 in the right bank and honestly preferred the KT170
Yes. That’s what I said for balanced. If you ran SE you could have tried what Ian is usingYou said you need 4 of the same pentodes running balanced, that's not correct..
XDMS is installed and can be used, but we'll probably use Roon primarily as a smoother option.I'm looking forward to this. Thanks for hosting.
Will the taiko extreme be running the xdms software?
Thanks to all who made it! We'll definitely be hosting more events going forward so do stay tuned!
Best,
Fred A.
There were a few and I've asked a couple to comment, but it was not a WBF exclusive event. It was a large pool of audiophiles from local clubs in NY, NJ, CT and a couple of other smaller forums.Were there any WBF members present at the event? Lack of impressions or any feedback from the end-users is very different from the Horizon launch event. Maybe Poseidon is too cheep a dac to interest most of WBF crowd?![]()
