When is a recap job not really a recap job?
As I have stated numerous times, I have been plagued by low level hum which does change in level by inducement from other electrical fields being too close to the power cord to the KSA-250. I paid Krell $1299 to repair my KSA-250 and for a "recap" job which I assumed meant all capacitors and especially the main filter capacitors as they see the most stress from the power supply.
I had a nagging suspicion that Krell didn't change out the main filter caps during the recap job. I called Krell yesterday and spoke to Ray and Ray said they weren't changed out as they only change them out "if needed." Again Ray told me how quiet my KSA-250 was after the repair job. I told Ray I wasn't happy as I thought the main filter caps should have replaced and the hum I have is common to both channels and they are a likely suspect. As filter caps get old and before they fail catastrophically with a big bang, they start losing their value. And by that I mean that a 1000 mfd cap might only measure 200 mfd for example.
I told Ray my worst nightmare was that I would pack the amp up, make the 3 hour round trip drive to the freight forwarder, send the amp back to Krell only to be told there is nothing wrong with it. Ray said he was going to call me back yesterday, but he never did.
I removed the Krell from my system earlier in the week and hooked up my pair of PL-400 Series 2 amps and they are perfectly quiet. Zero background noise which makes my noise floor whatever the source material's noise floor is. The problem is that PL amps are not close to being the same sonic league as the KSA-250. Nothing sounds *right* with PL amps compared to the Krell. The bottom end isn't as deep and extended, mid-bass is nonexistent, and voices aren't as fully fleshed out. In other words, it's almost threadbare by comparison.
I couldn't stand it anymore and put the KSA-250 back in the system last night. I hate to say it's night and day, but it's night and day. The KSA-250 passes through so much more information it's just incredible. Now if I could only make it not pass through the low-level hum I would have it made.
