Thank you Amir, again for a very clear explanation. :b
And
ARCOS uses what type of digital filters Amir?
Are they the Parametric type?
Or are they the Finite Impulse Response (FIR) type, with both Frequency Response and Time Domain adjustments? [Audyssey uses that type.]
Or are they the Infinite Impulse Response (IIR) type, also taking into consideration room acoustic delays (reverbs)?
Or are they a combination of the last two above? [Anthem with ARC uses that combination.]
Or are they different?
And, are they similar to Audyssey filters in the bass for multiple subs EQ (or two separately calibrated ones)? ...FIR digital filters, with emphasis in the low Bass frequencies, down to 10 Hz ...
Also, you said before that ARCOS with QLS is much more advanced than Audyssey.
Is that including Audyssey MultEQ XT32 and Audyssey MultEQ PRO? ...With over
10,000 FIR digital filters.
[Lexicon with ARCOS & QLS is a no go now. So that leaves JBL Synthesis with the new upgraded ARCOS, Version 3.0, in this field; at least in the now.]
[[QLS stands for Quantum Logic Surround, and was supposed to add additional Height channels, correct?]]
And last, what is your take on TRINNOV?
Thank you sir.
P.S. I found
this.
