Leading High-End Audio Designers
MylesBAstor
90
1,725
New York City
With time, the cj thread morphed into members talking about the leading designers in the high-end industry. So let's switch gears and hear which designers (or even stores) do you feel have had the most significant impact upon the high end audio industry?
Dan D'Agostino
Vladimir Lamm
William Z. Johnson
OK here's a starting list for discussion of whom should be in the High End Hall of Fame (that was started years ago by Academy for the Advancement of High End Audio aka AAHEA):
Speakers:
Jon Dahlquist
Jim Thiel
Jim Winey
Arnie Nudell
David Wilson
Peter Walker
Mike Wright
Edward Villchur
Arthur Janzen
Henry Kloss
Jim Rogers
Jim Strickland
Electronics:
Tim de Paravicini
Dan D'Agostino
Stuart Hegeman
Sid Smith
Dick Sequerra (could also go under speakers)
David Hafler
William Z. Johnson
Mark Levinson/Tom Colangelo
Julius Futterman
James Bongiorno
Sidney Corderman
Mitch Cotter
Nelson Pass
Analog:
Yoshiaki Sugano
Joe Grado
David Fletcher
Herb Papier
Sao Win
Harry Weisfeld (record cleaning machines)
Cables
Bruce Brisson
Noel Lee
Multi-contributions:
John Curl
Keith O. Johnson
David Manley. You want high watts and bass amps in a tube amp? No problem.
Bob Carver. The P.T. Barnum of High End. Not to mention a damn serious designer when he put his mind to it.
John Curl. He proved there was no reason solid state could not sound like music.
Gayle Sanders et al. He proved that electrostatics could serve the masses.
SOTA-Robert Becker Letters submitted to Sterophile suggest who the actual genius was is in dispute. A glass bearing (ruby), vacuum hold down, and different take on springs. Instead of sitting the table on top of the springs ,he hung the table from the springs. Making them much easier to tune. All at a price you could afford.
SOTA-Robert Becker Letters submitted to Sterophile suggest who the actual genius was is in dispute. A glass bearing (ruby), vacuum hold down, and different take on springs. Instead of sitting the turnble on top of the springs ,he hung the table form the springs. Making them much easier to tune. All at a price you could afford.
If I put Gayle on and I have no problem with that, then would also have to list Ron Sutherland
I'm curious to whom you credit the SOTA design. If memory serves me correct, SOTA was Rod Hermman, Robert Becker and David Fletcher. Rod Hermman also designed the Arcici triangle shaped table many years back for Ray Shab. Then later came Allen Perkins (?) and some others I think.
Linn's Ivor Tiefenbrun
I thought about Ivor but how much did he design and how much was he a promoter? I also held back since I thought possibly one could make an argument for the Gale or AR tables as being the predecessors of today's tables.
Becker and Perkins give the nod to FLetcher. I credit Sutherland who also gets credit for his battery powered preamp. Did anyone mention Peter Walker for Quad?
Becker and Perkins give the nod to FLetcher. I credit Sutherland who also gets credit for his battery powered preamp. Did aanyone mention Peter Walker for Quad?
Yes on Walker :)
Myles ,did Richard Heyser ever make a speaker? Certainly he deserves some kind of mention.
Good question. Not off the top of my head but perhaps someone else knows.
Not that I know of but at least two of his alumni Nelson Pass and Albert Von Schweikert have made names for themselves.
Dick Heyser
Tom Danley
Peter Walker
Nelson Pass
Other worthies:
David McGrath (Lake)
Bob Stuart
We all forgot Richard Vandersteen. He also has patents in the area of cable design.
Alon Wolf of Magico.
Pflash Pflaumer of Berkeley Audio Design.
Juergen Reis at MBL (30+ years).
