This has got to be the longest rally in the history of WBF. You guys got stamina!
It's the audiophile voodoo triathalon.
Tim
Nah. If you have the tweeter right up to your ear and what you hear is perfectly coherent driver integration, you're making good use of a vivid imagination, not psychoacoustics. But let's say it is psychoacoustics, that the human brain has the ability to imagine the full, undistorted music and fill in the blanks, when the ear is only hearing the blast of a piezio super tweeter from a HTIB speaker from just a couple of inches away.....
This has nothing to do with your tweaks except that your mind requires that you do something before it will convince you that what cannot be is. You could just as well have tweaked the plumbing as the power supply, Frank. It's a question of what you can convince yourself is real, not reality.
Tim
Remember, I am not asking the system to be a guitar amp, just to reproduce what was added into the mix. I have run the type of stuff you're talking about, without a problem. One of the test tracks is a live version of Hendrix - Voodoo Chile (Slight Return), beautifully recorded. The Marshall growls, churns, bites and screams like it should from the right speaker, from the left the drum kit is clean as you could wish for, cymbals shimmering beautifully.
I mentioned once my brother played in bands, I been next to a Marshall in heat many times ...
Frank
I'm pleased that I managed to get a pretty good score on estimating your system's capability! My little HT setup, at 1 metre I estimate would only be capable of 105dB peak, you have at least another 10dB, possibly 15dB above that. Tim, I have tracked down some figures, and you should be capable of 116dB peak at 1 meter, well above me. So both of you gentlemen should easily be able to outgun me on raw horsepower needed ...
A test recording? When the system is humming it will work for any recording, but an easy, obvious starter would be a nicely played violin solo, one that has good, sweet tone. You should be able to go up the tweeter as stated and not lose any of that tone: if it starts to become harsh and edgy the closer you get to the tweeter then the invisibility thing won't work, there's still too much distortion in the system. If you don't lose the tone on that recording try a more "difficult" violin recording, and so on ...
As regards ear damage, as you say, low distortion minimises problems. For me, I start to get ringing in the ear which is the body's way of telling you to back off, which I immediately do. You only have to do the test momentarily, a few seconds will give an answer either way.
Frank
But who's McEnroe and who's Borg??
Frank
Okay, let's do some maths! A Marshall box uses drivers of around 98-100dB sensitive, but they generally have poor power handling, it's all about efficiency. So they're wired up, say, 4 in a box so they can take the punch of 60 or 100 watts of tube power. This all translates, being generous, to being able to deliver 120dB peak at 1 metre. Step back to 2 metres away from the real Marshall, down to 112dB, step again to 4 metres away, down to 106dB; goodness, still sounds like a Marshall to me! But, hey, that's what I said my pitiful little Philips can do as a peak level. So there is no theoretical reason why my setup at 1 metre away from a speaker can't sound like a Marshall that's 4 metres away, even on 11!!Frank, remember I am talking about a system's ability to EXACTLY reproduce a 'live' instrument or a 'live' orchestra. So much so that when a listener hears said system, there is no perceivable difference between the two events and the 'live' event has been reproduced in all its facets. ( which is and always has been the 'holy grail' of all a'philes).
In other words, the system can completely fool even the best trained ear on the planet into believing that they are in the presence of the real instrument/event.
So, your above statement tells me that you are confusing an illusion of a Marshall stack's sound on your system with the true sound of a Marshall stack...the real instrument if it was actually in your room would be analogous to you having a small somewhat fuzzy photo of said instrument in your hand ( the sound of your system) and then standing next to the real thing(the sound of a 'live' Marshall stack in your room) and looking at the difference!
Wrong headspace ...I don't know McEnroe, but Borg?
...heavily tweaked.
Tim
I'm really talking about the bite and the grunt of the guitar amp. One of them in your lounge has plenty of that "palpability" that everyone loves, that's what I want to get happening!You are never going to replicate the acoustic space as it will change in every venue the stack gets played in including your own livingroom.
Gary, I agree entirely that the physics make sense, the trouble is that one's ears are not that sensible!Thanks, Tim.
Frank, as I mentioned earlier, if the tweeter is 1/4 wavelength at the crossover frequency away from the midrange, what you described is absolutely correct if your ear is also less than 1/4 wavelength away from the midrange and tweeter. I'll give it the benefit of doubt, and increase that to 3/4 wavelength at crossover frequency.......
I am not quite sure whether the tweeter disappeared or not for you, but unfortunately you picked about as bad an initial test as possible; I did suggest using solo vioin. The Branigan WILL work if everything is right, but that is a far step ...I use a 33 rpm mix LP Disco music ( non audiophile recording with normal equalization on this kind of music from the 80's. ), Laura Branigan: Self Control ( Atlantic label. ).
This recording is a hard/severe test for any home audio system and only system with low distortions can handle at high SPL. Well things are that when I was listening I remember you and with out " think on risks.. " I stand up and put ( very briefly ) my right ear almost touching the speaker tweeter and yes I had not the feeling I was hearing the tweeter: almost disappear.
Of course I knew I was hearing ( after the test ) because the " ringing/noise " that left in my right ear..
There are at least 3 people that have made this happen: me, Vince, Roger; Robert at times, Jack at odd moments. In fact, I am sure most audio people have had it happen momentarily but then it went away, so they just ignored it, put it in the "I am not quite sure what that was about, but, gee, it was good!" basket ...
Frank
well, someones' gotta say it, may as well be me
Frank, you're being foolish.
Firstly Mr Aim For No Distortion, have you got those graphs and figures for your little three inch drivers frequency response yet?
No? Ok, got it. You'd rather just tell us how your three inch drivers recreate the stack of marshals eh?
Now, your 'proofs' using varying distances. Gee, in winter, it gets cold out here at bathurst and being in a big old house don't help matters much.
But the quotes and costs to heat the place!! NOW, thanks to you, I can see all I need to keep warm is a few matches. See, the way you have so eloquently explained things I figure that if I would be nice and warm five metres from the blazing wood fire (do the maths yeah, use the inverse square law) then if I stay 1 mm from the match...it IS after all a temperature over a thousand degrees at the head is it not??....then that will equate to being in front of the fire but five metres away.
Now, using your examples of the marshal stack (WHY is anyone even trying to talk to frank? What are the forum rules about trolls??) are you claiming you can deliver clean undistorted 106 db peaks at your LP at all frequencies using your piddly three inch drivers and piddly sub that comes with it?
Ok, sweep please. No more bullshit, show us your in room response from the LP.
And whilst we are at it, why do you continue to be intellectually dishonest even when it comes to your own silly proofs?? On the one hand you do not take the raw clean continuous output of the marshal stack, you count backwards sufficiently till you reach the peak output (you think, bet my bottom dollar you have never taken measurements of your drivers and know zero about them) of your three inch drivers, and STOP there.
Why do you not then work out the output of your three inch full rangers at the lp? Why stop when it reaches your maximum? After all, the diminishing output with distance works equally well with your three inch drivers (I keep emphasising that, this IS the crux of the matter) as it does for the marshall stack?
What figures are you using to work out the db change at varying distances?? For a point source, line source, an array? I imagine they would be different, I'll let the true knowledgeable answer that (it ain't me, and it certainly ain't you frank). You start with 120 at one metre, give us 112 at two and 106 at four. sounds fishy to me.
At least a troll (I would assume) has an idea that he is just laying on crap, just does it for fun. Frank however has no idea how he is coming across.
Dunno who to pity more.
You've got one point against me, should have been 114 at 2, 108 at 4. Of course only half-wits like me believe that sound intensity drops off 6db for every doubling of distance, the morons who write textbooks on sound behaviour are nowhere as knowledgeable as all you fine gentlemen ...well, someones' gotta say it, may as well be me
Yep, but at 1 metre, sometimes it is actually worth reading what I said, just like a huge number of loudspeaker manufacturers who quote sensitivity and power handling figures. Any half decent system off the shelf anywhere should be able to do that, the anchor around their necks is crap electronics driving them.you claiming you can deliver clean undistorted 106 db peaks at your LP at all frequencies using your piddly three inch drivers and piddly sub that comes with it?
Dead right, DaveyF -- be afraid ... be very afraid. The contagion is spreading, like an insidious cancer, it might seep into all corners and contaminate innocent young audio virgins, who may end with the ludicrous idea that that you can enjoy playback sounding as good as the real thing. A very dangerous, destructive malaise ...I for one have come to the conclusion that perhaps we should just label Frank and his system as an anomaly and leave it at that.
OTOH, the unsettling point to me is that he is seemingly beginning to get other believers in his ideas and thoughts...hmm![]()
